wont fire up after i Changead TPS and crank sensor on 4.0l - JeepForum.com
post #1 of 3 Old 05-21-2010, 09:49 AM Thread Starter
evan422
I had codes for tps and crank sensor flashing, so I replaced them. The codes for them cleared and it ran alright for about 20km, then started to sputter and died. Getting started was tricky, I ended up pulling a plug to check my spark and then it started on 5 cyls. It missed even with the plug back in and now I get a 54 code which to my knowledge is cam sensor or distributor timing. Is there a way I caused this? Or coincidence?
evan422 is offline
post #2 of 3 Old 05-21-2010, 10:02 AM
Que89YJ
Are you still missing? The code is correct. Clear the codes by disconnecting the battery and see if the fault reoccurs. If it does then its time to replace the distributor pickup sensor.
Que89YJ is offline
post #3 of 3 Old 05-21-2010, 10:49 AM Thread Starter
evan422
Yeah I had the battery disconnected over night, it started right up, still missed. Then turned it off and it didn't start again. Yeah I'll go pick up a new sensor. I've been trying to clear up my rough idle and its starting to feel like I'm creating problems. Thanks for the advice.
evan422 is offline
91 yj 4.0, crank,crank,crank wont turn over hasher09 YJ Wrangler Technical Forum 20 08-04-2010 11:43 PM
4.2 will crank but wont fire 89yjmudman YJ Wrangler Technical Forum 6 04-13-2009 08:33 PM
Desperation, 1993 Jeep will not fire..replaced brain, crank sensor, ignition coil... amsgwp YJ Wrangler Technical Forum 3 03-24-2009 12:15 PM
wont run......? crank fire and air but wont run Eric93 YJ Wrangler Technical Forum 14 08-06-2008 08:12 AM
clutch wont engage and jeep wont fire natehate TJ Wrangler Technical Forum 4 04-19-2007 07:10 PM
