Won't start-solenoid??? - JeepForum.com
post #1 of 4 Old 07-27-2002, 08:27 PM Thread Starter
BigBobG
Jeep was starting great.
Then next moment just got the clicking sound.
Thought the battery was low and jumpered it.
No different.
Replaced the solenoid and still nothing.
Removed the starter motor and applied power directly with cables and found it wasn't working.
Replaced the starter motor and tried again. Nothing. Jumpered the solenoid on the starter side and it cranked. So the starter is functioning.
I have no idea what is the problem. Used the multitester and have power to the relay side of the solenoid 12 volts and 6 volts on the other. I.e.when face the solenoid from the front of the vehicle, there are two small wires on the front of the solenoid. I assume the power side is the one on the left. The one on the right has 6 volts.
Is there a another relay between the ignition and the solenoid assembly??
Need some input....will try again tomorrow.
P.S. What is the test to ensure the solenoid is functioning properly.
I already know the starter works great.
Signed ..... walking.
87 YJ 4.2 litre, 5 speed, Stock
BigBobG is offline
post #2 of 4 Old 07-29-2002, 07:10 AM
Fern
Wont start solenoid??
The disconected wire that kept my solenoid from cranking is located on a terminal block on the pasenger side firewall just below the Vacuum switch that turns on the "4x4" lite on your dash. The terminal block has about four or five blade type connectors on it. Yours may just need to be reseated(not making good contact) or it might have slipped off like mine did.
Fern is offline
post #3 of 4 Old 07-29-2002, 01:58 PM
jmsjeep
I know this sounds to good to be true. My jeep just stopped starting one day, some times a click sometimes not.
I was geting power at the starter when testing but it wouldn't start. After alot of @#$% I filed my battery cable connectors with a circled file and used a wire brush on the battery terminals. They looked fine no corrossion, but I was trying everthing. It worked fine the very 1st try after that. Something must of built up over time and was allowing some power through, but not enough to start.
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #4 of 4 Old 07-29-2002, 07:32 PM Thread Starter
BigBobG
Starter motor was fried and shorted.
Removed it and did a bench test, ie. hooked up battery directly with jumper cables and it wouldn't turn.
Smack it with a hammer to free up the brushes, but still didn't work.
Replaced the solenoid and starter motor as a pair and clean the terminals.
Off and running.
Cost $96 for rebuilt starter and $16 dollars for a solenoid.
Not bad and l learned about starting systems.
BigBobG is offline
Odd electrical start problem after stereo instal ... relay not solenoid clicking mich27 YJ Wrangler Technical Forum 1 09-09-2009 08:12 PM
88 YJ Replaced Solenoid still won't start Jlamky25 YJ Wrangler Technical Forum 0 04-25-2009 10:54 AM
Freakin Start Solenoid Lumpymayo YJ Wrangler Technical Forum 21 09-19-2008 09:01 AM
Solenoid Optik45 TJ Wrangler Technical Forum 1 05-28-2008 10:19 AM
my starter solenoid blew... can i simply replace the solenoid? hmk_21 YJ Wrangler Technical Forum 11 08-30-2006 12:34 PM
