won't pass emissions 4x4 not engaging. - JeepForum.com
post #1 of 14 Old 07-26-2012, 05:36 PM Thread Starter
JulianJ
I have a 90' YJ 4.2 I6 that is completely stock. All the vacuum hoses are not dried out and rotted. I've put a new cat converter on it and and completely new exhaust system minus exaust manifold. its running about 600rpm idle. drives fine. the transfer case is fine and when going into 4H or L the front driveshaft turns but theres no power to the front wheels. the vacuum motor on the front axle seems lose i can rotate it. when i got it the blue wire coming from the transfer case was unhooked and the other end coming from the canister under the battery was plugged. I unplugged it and it sucks and i hooked it back up to the blue wire but right when I do this the 4wd light on the dash comes on even if 4wd is not engaged. I'm thinking that replacing the vacuum motor will fix the 4x4 but will it help in emissions at all?
i've gone and tried eveything I know to pass without buying the "it'll pass or double money back deal"
limit on CO: 1.2
Reading: 1.8
The testing guy is very nice and he's trying to figure out what it could be doing and we were chasing down and vacuum leaks but the lines are all there except for the ones that go from the air cleaner to exaust manifold to direct the right air temp when warming up. I can post pictures for anyone willing help any input would greatly appreciated.
JulianJ is offline
post #2 of 14 Old 07-26-2012, 11:13 PM
NonRubicon
Sounds like the 4WD vacuum lines are boogered up. Not sure about the cause of the smog fail though.
Check this thread for info on the 4WD vacuum motor hose layout:
http://www.jeepforum.com/forum/f12/4...5/#post5427272
Make sure you have everything connected properly and that there are no vacuum leaks. Maybe someone else will jump in and provide some help on the smog problem.
NonRubicon is offline
post #3 of 14 Old 07-27-2012, 06:36 AM
jojojeep1
dont worry next year you get a saffty only $21 , at least i have been saffty only for two years, 88 yj on longisland n.y jeep has to be 20 years old, you might be able to do that also ask them they wont just tell you ,
jojojeep1 is offline
post #4 of 14 Old 07-27-2012, 08:35 AM Thread Starter
JulianJ
What is saffty? I know antique tags we can get down here but there is emissions on every vehicle in the county unless it is 74 or older. Down here you can register a vehicle antique tagged if it is 25 years or older and even then it can only be driven for general transportation on saturday and sunday. The there are other stipulations like you can drive to car events and to get it worked on but not as a daily driver which is bogus. The fine for using your car as a daily driver is five years without being able to register a car as antique.
Is it odd that coming from the vacuum motor on the front axle I have four vacuum lines coming out?
JulianJ is offline
post #5 of 14 Old 07-27-2012, 08:36 AM Thread Starter
JulianJ
Whoops. If a car is antique tagged then no theres no emissions but then it can't be a daily driver.
JulianJ is offline
post #6 of 14 Old 07-30-2012, 01:36 PM
evilpersona
Actually in NY anything that is OBDI is now just safety only. so anything 95 and older.
evilpersona is offline
post #7 of 14 Old 07-30-2012, 03:38 PM
jokerchief462
Here is a great site that explains all the smog stuff. Reading each section on the test and results will give some ideas of what you are looking for and how to find the fix.
http://www.smogtips.com/functional_inspection.cfm
jokerchief462 is offline
post #8 of 14 Old 08-01-2012, 11:35 AM Thread Starter
JulianJ
Thanks jokerchief462 but I'm still not passing. Some people believe that the lines on the carb for idling could be clogged and I'm beginning to hear that back then when these were new some dealerships recommended expanding the idling lines so they don't get clogged so now I'm just waiting to get another paycheck then I can do more and buy the tools to expand them to I think they suggest 0.03102 or something or just buy new lines. I'll keep ya' updated.
JulianJ is offline
post #9 of 14 Old 08-01-2012, 12:17 PM
NonRubicon
If you are noticing fuel drip from the venturi nozzles happening at idle, I would suspect there is crap clogging that circuit. Neither venturi nozzle should be dripping at idle, and both should mist when you give it throttle. If not, then you have a problem.
But in any case, if you think it's something internal to the carb, a simple teardown/cleaning/rebuild would suffice long enough to pass smog (provided that it didn't pass before because the carb was dirty). Rebuilt kits are inexpensive and you don't need any special tools to rebuild the carb. The drilling out of the idle pickup tubes is just the long term solution to the problem of the tubes getting clogged easily.
If you already haven't seen this site, here's a link to the best resource online that explains the OEM 4.2L setup: Adventures Under the Hood
If you are running stock with a functional computer, you'll need to make sure everything is working as it should, otherwise you'll probably not pass.
post #10 of 14 Old 08-01-2012, 02:41 PM
redbullrr
1987 YJ Wrangler
So if my Jeep is an 87, I dont have to pass emissions? Just double checking cause I have not gotten an inspection due to my exhaust being rotted out. I was gonna pay the guy 100 bucks to pass it. LOL
redbullrr is offline
post #11 of 14 Old 08-02-2012, 02:29 PM
redbullrr
1987 YJ Wrangler
bump, anyone in the NY area care to chime in
post #12 of 14 Old 08-06-2012, 08:58 AM
evilpersona
in ny anything obd1 is not emissions tested anymore. this is what i heard from a mechanic that does inspections. so 95 and earlier
post #13 of 14 Old 08-08-2012, 06:52 PM Thread Starter
JulianJ
Looks like Tennessee should follow up on Ny ha. I'll look into venturi nozzle and if its dripping then i'll get back to this.
JulianJ is offline
post #14 of 14 Old 09-24-2012, 12:52 PM Thread Starter
JulianJ
No drips. rebuilt the carb also to be safe and tuned it. Seems like it was done not to long ago the needle looked somewhat new and not 20 years old.
JulianJ is offline
4wd , 4x4 , emission , emissions , vacuum
trying to get my 4.2L to pass emissions Juno7 YJ Wrangler Technical Forum 4 10-12-2008 04:54 PM
Is it possible to pass MA emissions without a cat? mflave007 YJ Wrangler Technical Forum 8 05-18-2006 09:30 PM
How is the the 360 going to pass emissions? JOKER4INK YJ Wrangler Technical Forum 9 11-10-2005 08:00 PM
Would Not Pass Emissions gustaia YJ Wrangler Technical Forum 6 01-13-2005 02:51 PM
Help! I can't pass emissions... jisl YJ Wrangler Technical Forum 3 06-14-2004 12:56 PM
