wj knuckles. - JeepForum.com
post #1 of 15 Old 03-31-2006, 07:08 PM Thread Starter
jipjip
jipjip's Avatar
wj knuckles.
i was at work today, and finally saw a wj come into the shop (it's a nissan dealer),
so i peeked under it to see how different the knuckles are. they look awesome, but the lower ball joint looks a lot beefier than mine. do the knuckles fit on the stock ball joints???
also do the brake lines bolt up to the wj calipers w/o problems???
and my last question... how much do i expect to spend for a pair of j/y wj knuckles??
thanx.
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #2 of 15 Old 04-01-2006, 02:19 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Around here I can get the knuckle assembly and calipers for @ $75 each
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #3 of 15 Old 04-01-2006, 04:54 PM
zeeman918
http://cgi.ebay.com/ebaymotors/ws/eB...3AAAQ%3AUS%3A1
Just found this. too bad its the only side they have
Jeep-less for now...
zeeman918 is offline
post #4 of 15 Old 04-02-2006, 01:22 PM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
What is the benefit of the WJ knuckles for those of us that are stupid?
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #5 of 15 Old 04-02-2006, 04:26 PM Thread Starter
jipjip
jipjip's Avatar
wj knuckles allow the drag link to be put higher on the knuckle than the stocker giving a high steer setup, but technically it's crossover steering cause the tie rod stays in the original location. it will help w/ soa setups b/c it puts the drag link over the top of the spring, and straightens it out to prevent bump steer.
jipjip is offline
post #6 of 15 Old 04-03-2006, 09:15 PM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Well ... I just did a little poking around ....
Unles I am mistaken, I could get an entire WJ D30 and swap everything to a YJ (or TJ/XJ) D30 and end up with not only bigger brakes, but also with crossover steering. 15 wheels will require the calipers to be ground but other than that is there anything I am missing?
I see a lot of guys making spacers and stuff ... but if I used all the WJ parts, aside from grinding and making a new tie rod / drag link it should be a bolt on affair correct?
post #7 of 15 Old 04-03-2006, 09:29 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
I believe the bolt pattern is different.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #8 of 15 Old 04-03-2006, 09:50 PM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Ahhhh ... I knew there had to be a reason so many people were making spaces and such
post #9 of 15 Old 04-04-2006, 10:27 AM
ErikJordan
Pimp Hand
ErikJordan's Avatar
the bolt pattern is the same.
the 1/4" spacer is required to get the rotor off of the knuckle.
it is a nice mod with some BADASS brakes.
there is welding involved.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #10 of 15 Old 04-04-2006, 01:03 PM
fratis
fratis's Avatar
someone needs to post pictures of this.
fratis is offline
post #11 of 15 Old 04-04-2006, 02:07 PM
RatherBeJeeping
Try that again Erik?
John
95.5 YJ with "stuff"
RatherBeJeeping is offline
post #12 of 15 Old 04-04-2006, 02:31 PM
Doublehead
Doublehead's Avatar
Don't use spacers. You will lose strength because the hub will barely sit inside the knuckle. It's better to drill another bolt pattern (5x4.5") on the hub's flange.
Doublehead is offline
post #13 of 15 Old 04-04-2006, 09:18 PM
Cobra Jeep
No, you need the spacer. The WJ knuckles are slightly (1/4in) shallower than the YJ ones (when measureing from the centerline of the ball joints to the hub mounting surface) So if you try and bolt on the wj knuckles without the spacers, the axleshafts will bottom out on the diffrentral before the hub is bolted down. The spacer is required for the conversion.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #14 of 15 Old 04-04-2006, 10:01 PM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
I think the WJ bolt pattern is different ....5 on 5 or something. Which is why people are using the TJ hubs..... which need the $25 (each) JKS spacers and would have weld them to the knuckle....
Welding to the cast knuckle? Does anyone have decent pictures of this?
I guess I would just prefer to not have too many custom parts for something like this so that when something breaks it can be easily replaced...
Here's an interesting take on the spacer part .....
http://homepage.mac.com/rv6a/hi-steer.html
Looks like they used some "indexing dowels" to take some of the load off the 3 hub retaining bolts. I'm not sure how I feel about that. Now maybe if they retapped the hub to used 3 big fat grade 8 bolts or something I'd feel better about it.
post #15 of 15 Old 04-04-2006, 11:48 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
it wasnt clear which "bolt pattern" was being referred to. i have the warn hub conversion, and retained it with the wj swap.
i was thinking the 3 bolts that hold the whole knuckle assembly to the hub.
Nicked up Knuckles & a lot of #%*@!!!! rayzordee JK Wrangler Technical Forum 16 04-23-2008 04:14 AM
30 knuckles on 44? Chris98TJ TJ Wrangler Technical Forum 6 02-26-2008 10:30 PM
30 and 44 knuckles same? Muddeprived TJ Wrangler Technical Forum 1 09-03-2007 06:29 AM
knuckles yellow04 TJ Wrangler Technical Forum 1 04-03-2007 02:49 AM
Knuckles Anyone????? timatoe YJ Wrangler Technical Forum 4 03-25-2007 12:12 PM
