WJ Conversion with 1 ton tres - JeepForum.com
post #1 of 11 Old 06-29-2011, 06:53 AM Thread Starter
Hawk37
I saw a couple WJ's last time I was in the Pull-a-Part. So, now I'm doing my homework on the swap. Has anyone done the conversion with 1 ton tres? Got pics?
From what I've read, I'll want to go with 1.25'' OD DOM to keep my diff from limiting my steering range. I'm guessing these tres would help too?
EX23434L TIE ROD END
I've read a lot of threads about 1 ton steering and WJ conversions, but not much is mentioned about doing both. Thanks guys
Hawk37 is offline
post #2 of 11 Old 06-29-2011, 12:13 PM
troy.j
i like the idea of those ends. i wonder how they work real world.
99 tj, 00 wj, 95 yj
...ask those who have bled of the cost of freedom and honor those who gave that others may have what we take for granted...
troy.j is offline
post #3 of 11 Old 06-29-2011, 12:17 PM
RatherBeJeeping
IIRC WJ stuff is 24mm and "1 ton" stuff is 26mm. I went WJ and never gave it another thought
John
95.5 YJ with "stuff"
RatherBeJeeping is offline
post #4 of 11 Old 06-29-2011, 04:58 PM
Cobra Jeep
I have WJ knuckles and brakes and a 1 ton TRE kit from parts mike on my YJ. When I installed it I tried re useing my stock tierods , but they were a bear it get on and they would rub the top of the springs. WJ steering arms are a little lower than the stock YJ stuff. Also they are a little farther in, so the stock tie rod had to be adjusted out a lot to make the alignment right. I only drive like that for a few miles just to get back to the house (did the swap at a friends house)
I then ordered the hd steering kit from parts mike that had the 1-1/8 dia, .188 wall tierods and 1 ton tre's. I then bought a reamer and reamed out the knuckles to put the tierods on top of the steering arm. Also reamed out the pitman arm.
Dont forget about the 1/4 inch thick spacer you have to weld to the knuckle.
'93 YJ 4.0L, AX-15, NP-231HD/SYE, 8.8in rear, OME 2.5 lift, home made front hub conversion, hydroboost. Warn M10000 winch. Currently building a stroker.
'79 Cherokee Chief, 401 MPFI fuel injection, T-18/D-20 and hydroboost. Otherwise stock.
Cobra Jeep is offline
post #5 of 11 Old 06-29-2011, 08:34 PM Thread Starter
Hawk37
Thanks Cobra, that's exactly what I wanted to hear. I was assuming I'd need to ream out/sleeve everything to use the 1 ton's. I like the GoFerIt inserts. Did you use the jks spacers? flip the tie rod up? and which ends did the parts mike kit come with?
Does anyone know if it would interfere with a later SOA if I flipped the tire rod up on the wj knuckles?
Hawk37 is offline
post #6 of 11 Old 06-30-2011, 06:28 AM Thread Starter
Hawk37
RatherBeJeeping, I've head the solid ZJ tie rod is beefy. Does the WJ have a beefy tie rod & drag link too? I think I read that either the drag or the tie was pretty weak, and I'm not sure if I like having tres with bends in them.
Hawk37 is offline
post #7 of 11 Old 06-30-2011, 05:58 PM
Cobra Jeep
I did not use any inserts with the TRE's, I simply used a tapered reamer from the top and drilled down. Had no problem making the new tapered holes for the new TRE's.
Its been so long ago I cant remember, but I do believe it was JKS that I got the spacers from. I used a spare junk bearing/hub assembly to hold the spacer on and had a friend tig weld them into place.
As for what ends the parts mike kit came with, I have no idea. I know the drag link attaches to the right side TRE.
Now it has been several years since all this was bought, so things may have changed, but I think this is gonna be basicly what I used. The picture is identical to all the parts I am running.
http://www.partsmike.com/store/store...on=show_detail
post #8 of 11 Old 07-21-2011, 10:50 AM
gunselman
I randomly ran across this thread searching for other info. I am not sure on how this would work. You would have to drill out you knuckle to accept the larger GM taper ends. IF you look at JCR offroad they do something similar but it is an inverted T style of steering. So i guess it can be done. http://www.jcroffroad.com/Merchant2/...tegory_Code=S6
A lot of guys use the Teraflex offset Tie rod ends with Jeep taper when doing the WJ conversion. They are more expensive than the ones you posted. But you have to buy a $100 reamer to ream out the holes so that kind of negates the cost benefit. Availability may be better though. Guys have clearence issues with wheels when using the Teraflex offset ends. You have to use at least a 16" wheel to clear them. I imagine this holds true for these also. If not a larger wheel. The only way to really tell is try it. I know 16" moabs will clear with teraflex offset over the knuckle.
gunselman is offline
post #9 of 11 Old 07-21-2011, 11:04 AM Thread Starter
Hawk37
They make inserts that are a lot cheaper/easier than reaming. You just have to drill out the holes and weld in the inserts in whichever direction you want. I've read with a sua yj I'll have to flip the tie rod and drag link up to clear the springs, but with an soa yj you can't flip the tie rod up because it will be in the way of the springs. (can anyone confirm that?)
I'm sua, so I was planning on going with the cross over steering still with 1/2 ton tre's and dom tubing for the tie rod and drag link if I have to flip it anyway.
Hawk37 is offline
post #10 of 11 Old 07-21-2011, 03:06 PM
1tuffyj
im soa on stock packs (sit flat) with yj knuckles and 1 ton steering. i can tell u flipping the tie rod wont work, springs are dead nuts in the way. however, someone mentioned above the wj arms sit lower than the yj's so maybe it leaves enough room to clear the springs????
just food for thought
this problem is 1 of a few reasons im doin s10 bastards, flipping my tie rod would be nice.
the pressure makes us stronger, the struggle makes us hunger, the hard lesssons make the difference, and the difference makes it worth it.
1tuffyj is offline
post #11 of 11 Old 07-21-2011, 05:52 PM Thread Starter
Hawk37
Yeah, I think I read on another thread that you can't flip up the tie rod soa, unless you get a euro driver's side wj knuckle and use an inverted t set up. I've been looking into this because my steering pops when I straighten out after a tight turn. I decided its just telling me to upgrade next. Anyone running wj knuckles soa?
Hawk37 is offline
Non-tapered TREs? pmccoy9876 TJ Wrangler Technical Forum 25 06-18-2011 09:31 PM
TREs and Ball Joints bradcoudriet YJ Wrangler Technical Forum 10 05-27-2010 02:07 PM
Adjusting my Toe in. Drag link wont move on TREs ...HELP Torn66 TJ Wrangler Technical Forum 8 05-20-2009 02:39 AM
TREs and drag link joints.... dbikers YJ Wrangler Technical Forum 1 09-20-2007 10:45 PM
Opinion: Heims or TREs? zeeman918 YJ Wrangler Technical Forum 11 01-28-2007 03:41 PM
