wiring questions - JeepForum.com
post #1 of 13 Old 04-29-2014, 06:36 AM Thread Starter
randomtrailhero
I'm looking for a few wires to get my gauges working again. It's a 95 yj which wires are for the oil pressure gauge the temp gauge and the volt gauge. This is where I'm looking to splice in at any help would be appreciated
randomtrailhero is offline
post #2 of 13 Old 04-29-2014, 08:39 AM
Que89YJ
Random PM sent with the info to download the factory manual with the wiring.
Que89YJ is offline
post #3 of 13 Old 04-29-2014, 10:35 AM Thread Starter
randomtrailhero
Thanks I'll take a look at it after work. Almost done with my 347 swap abd the wiring is proving to be very annoying.
post #4 of 13 Old 04-29-2014, 12:05 PM
Que89YJ
You can use the pdf and search on the wiring color abreviations to nail it down.
Que89YJ is offline
post #5 of 13 Old 04-29-2014, 02:42 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
This plug is under the dash;
Circuit G60 is your oil pressure gauge
Circuit G20 is you temp gauge
Ooops dinner time!!
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #6 of 13 Old 04-29-2014, 03:48 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
The voltage gauge seems to gets power from fuse #9 in the fuse box under the dash.
I have to assume the other side of the gauge receives a resistance value from the temperature sending unit.
That seems to be a DKBL/WT wire that comes through the right plug in your picture. Pin is three rows down and three rows in. It is possible that it is a double crimped wire pin.
post #7 of 13 Old 04-29-2014, 06:44 PM Thread Starter
randomtrailhero
Thanks for all your help guys! my jeep just moved from athens to Albany oh today, a couple days ahead of schedule so unfortunately it will be a couple Days before I get to work on it again.
post #8 of 13 Old 05-02-2014, 06:20 PM Thread Starter
randomtrailhero
My gauge is receiving a signal but now it just pegs out the second I go to start my jeep. The sensor pigtail has one white wire with a orange tracer and a black wire with a light blue tracer. Which wire should go to the oil pressure gauge. Which is gray with a yellow tracer. My original plug was a 1 wire sensor if that matters the new one is a 2 wire sensor.
post #9 of 13 Old 05-02-2014, 07:27 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
You have a two wire oil pressure gauge sending unit? I do believe that it is supposed to be a case grounded one wire unit.
Circuit G60 = gy/yl for oil gauge
That information was already posted above.
OEM # 5602 6779
http://www.quadratec.com/products/55108_07.htm
post #10 of 13 Old 05-02-2014, 07:40 PM Thread Starter
randomtrailhero
This is the sending unit I have
http://www.quadratec.com/products/917219_07.htm
The pig tail has two wire not the sending unit my stock motor had the same unit but the pig tail only had one wire
post #11 of 13 Old 05-02-2014, 08:00 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
[QUOTE=randomtrailhero;22627401]This is the sending unit I have
This is the sending unit you need; You can get that locally
http://www.quadratec.com/products/pr...6779&submit=Go
post #12 of 13 Old 05-02-2014, 08:47 PM Thread Starter
randomtrailhero
What's the difference between the two? The one I have now is the same style the jeep came with and the one that is being suggested was not on my old 2.5l.
post #13 of 13 Old 05-02-2014, 08:50 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
If your oil sending unit has one pin on the back of it pull the 2 wire adapter plug or whatever it is and hook it up to that G60 circuit wire I mention earlier...
