#1 | |
Wiring problems with 4.0l swap.
I'm about to lite a match to it, i'm discusted. The problem i have is i am using a 92yj harness and everyone else uses xj. I can't get any spark. the auto shut down relay has power to 30, 85, and 86 terminals which has me puzzled. There should only be power to 2 of those and 1 should be a ground. The other problem is no one can tell me which wires on the yj harness is the 5 wires to fire.
Help???? Steve
1989 Wrangler... [I]93 4.0L [/I], AX15 ,231 TC,Rough Country 4inch lift, 33 12.50 Baja Claws . |
#2 | |
H2 Recovery Team Member
as for the "5 wires to fire" i've never heard that phrase. care to elaborate?
RIP: '88 YJ 2.5L Ax-5 NP231 Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front. 92 YJ 4.0L Ax-15 231 5" springs, 1" shackle 31's or 35's depending on my mood |
#3 | |
I had the key on so i guess it is correct. I may hace a cps sensor problem. The 5 wires for fire is a saying people use when swaping 4.0l in older jeeps. That relay never does click, i will search the cps problem and see what happens. Steve
#4 |
At this point i'm wishing i would have put a small block chev in there. I think i may end up buying the Hesco harness to complete this.
Steve
#5 |
Are you going from a 2.5 to a 4.0? or was it a 258?
New Project "Pissed Wife" http://www.jeepforum.com/forum/f12/project-pissed-wife-747535/ |
#6 |
Was a 2.5l, i bought the jeep with a bad engine.
Steve
#7 |
I am not sure how much help I can be but I have the 87-90 chrysler student teaching guide with all the info you could ever need to know about the injection system on the 2.5L. It list all the diag points and wiring schematics for each year and the variants between each year. Anything you need to know I'll see if I can find it for ya.
#8 |
Just a though, there is a feature on most the FI jeeps that if the WOT is showing closed as in you are in WOT it will not fire. It is a feature for clearing a flooded engine. If you have not wired in that sensor yet or not correctly, it will not fire.
#9 | |
Steve did the engine run when you pulled it? where exactly does the spark path stop? if you don't get anything from the coil, and you have power out of the ASD relay then you've either got a break in the wire feeding the coil or the coil itself is bad. if it's further down the line then it could be the cap, rotor plugs, etc. a lot depends on where the spark path is interrupted.
#10 |
Thanks for the idears guys but i got it figured out last night and it was a bad cps. She purrs like a kitten now.
Steve
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
