Wiring problem - JeepForum.com
post #1 of 2 Old 10-02-2011, 05:22 PM Thread Starter
durrster1128
Wiring problem
I have a 1992 Jeep Wrangler, my wiring harness was cut, i got another wiring harness however i have power to everything and starter, but starter will not turn over when using the key. the dash harness is from a jeep with automatic but mine is a manual. what can be wrong? I think it maybe the neutral/clutch safety switch however i do not know how to bypass it.
durrster1128 is offline
post #2 of 2 Old 10-02-2011, 06:52 PM
bharris68
Daily Driver
Yes - very likely it's the Neutral/Park interlock for the Automagic.
Will this help at all? http://www.ehow.com/how_7657889_bypa...-cherokee.html you'd need to FIND the interlock wiring first, likely an empty plug by the Transmisson and then find the Factory Service Manual for the YEAR of the HARNESS you have. That will tell you what the voltage readings will be in either park or neutral.
bharris68 is offline
Wiring problem durrster1128 YJ Wrangler Technical Forum 3 08-17-2010 05:52 AM
Wiring Problem/ECU or idk...help bringbackphish YJ Wrangler Technical Forum 0 03-31-2009 05:55 PM
2.5L to 4.2L wiring problem XmansYJ YJ Wrangler Technical Forum 0 02-01-2009 12:52 PM
Another Wiring Problem twhditto TJ Wrangler Technical Forum 9 05-08-2007 06:39 AM
Little Wiring Problem..somewhere l_thurier YJ Wrangler Technical Forum 12 09-23-2006 07:34 PM
