wiring harness on back of instrument panel - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > wiring harness on back of instrument panel
Rough Country Jeep Suspension Deals at Rockridge 4WD!Amsteel Blue Synthetic Winch line Free ShippingWarn and Smittybilt Free Shipping Offer
Unread 04-07-2012, 10:11 AM   #1
Keepajeep
I am looking for a diagram of the wiring harness that plugs in to the instrument
panel. Trying to locate the wire to the fuel gauge.
1994 YJ
Jake Bondy,Sarnia, ON Canada
Build it, Break it, Fix it, Replace it, REPEAT !!!!!!!!!!!! Jeep......A way of life
Keepajeep is offline   Reply With Quote
Unread 04-07-2012, 10:52 AM   #2
pete1991YJ
The wire to the fuel gauge is tan with a black stripe, same color as the wire at the sending unit. On the bottom row of the plug that goes into the instrument panel. I may be able to dig out the diagram later on this weekend.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
91 YJ 2.5L 5-spd, 31" BFG ATs, mostly stock NO RUST 160K in WNY, Daily Driver
pete1991YJ is offline   Reply With Quote
Unread 04-07-2012, 11:01 AM   #3
Keepajeep
thats what I thought too. The wiring coming from the tank is DB,GN, BLK. GRN is to the pump, black ground.
I'll check the tan one again at the harness
Unread 04-07-2012, 11:13 AM   #4
Keepajeep
nothing on the harness on the back of inst. cluster that is tan. tried the DB, stilll nothing
Unread 04-07-2012, 11:19 AM   #5
pete1991YJ
The DB you refer to, is that dark blue or dark brown? Either way, there should be 3 wires at the sender: one is ground, one is power, and one is sender. The sender wire sould read anywhere from 0 to 90 Ohms depending how much gas is in the tank. This is what you should be reading at the gauge cluster connector *and* at the tank connector. Obviously if the readings differ then you have a wiring problem (open or short). The gauge itself must be grounded at the cluster (it shares a common ground on the left side of the circuit board). Or else it'll read wrong. The tank can be grounded anywhere.
Here's a tip for making sure the gauges all work:
http://www.jeepforum.com/forum/f12/r...ter-how-991307
