Wiring for flat tow setup - JeepForum.com
post #1 of 12 Old 11-18-2010, 05:47 PM Thread Starter
I8AHUMR
I'm wiring my YJ up for flat towing and ran across this. If you look about halfway down on the link you'll see the wiring diagram.
My question is why a third diode is not needed on the marker lights? I'm sure this setup works but all setups I've found, except this, call for four diodes. The write-up says one is not needed but doesn't explain why.
Thanks in advance.
YJ Flat Tow Setup
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #2 of 12 Old 11-18-2010, 08:01 PM
DirtyYj91
lol just buy some magnetic trailer lights with the 4 way wire from Harbor freight tools for like 12 bux and use it on whatever you want to, you can just put them on your bumper.
DirtyYj91 is offline
post #3 of 12 Old 11-18-2010, 08:03 PM
MoparFreak69
He wouldnt put a diode in the marker light circuit because you will want the front marker lights to light up, much the same as a marker light on a trailer. It just lets someone know that there is something between the lights on the rear of the towed rig and the lights on the rear of the towing rig, that they cannot just merge between the two like idiots often try to do.
My YJ was wired for towing when I got it. Someone just took a flat 4 trailer plug (both sides) and spliced it in to the front light circuit. It looks like when they towed the Jeep they just unplugged the flat 4 and that disconnected the front lights from the rest of the circuit. I guess if you are cheap it is an effective method to skip using diodes.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
post #4 of 12 Old 11-18-2010, 08:48 PM
jbolty
jbolty's Avatar
I just got a couple of $2 light sockets and added another set of bulbs to the existing tail lights then ran the wires up front through the frame.. Plenty of room in there.
jbolty is offline
post #5 of 12 Old 09-07-2012, 10:38 PM
jpgene
jbolty
Saw your rear brake light setup for towing. Looks great. Tried several local auto parts stores for bulb holder, saw nothing that would work.. Could you tell me where you found the bulb holder that will work. Thanks, jpgene
jpgene is offline
post #6 of 12 Old 09-07-2012, 11:07 PM
jbolty
jbolty's Avatar
Don't remember exactly. They were just some random socket I found at one of the auto stores.
I suppose you could get a set of the $10 harbor freight tow lights, strip it for parts and use the wire too.
Or here
http://www.ebay.com/itm/1PCS-BA15D-B..._qi=RTM1062687
jbolty is offline
post #7 of 12 Old 09-08-2012, 07:23 AM
Mechman71
Slick setup, jbolty! I use the magnetic lights myself, though I did have one fall off somewhere in Nebraska (or maybe Wyoming, I forget if I checked them in Laramie) and wound up having to buy another set...
'89 YJ 4.2 5 speed, Spinnaker blue/grey, hard top and doors, vintage fitted rear speaker boxes but otherwise stock and RUST FREE!!
Mechman71 is offline
post #8 of 12 Old 09-08-2012, 07:27 AM
CloakedLJ
This is what I have in my LJ, a much simpler set up then the diodes and cheeper too. If memory serves me correct those diodes are like $56 a piece.
CloakedLJ is offline
post #9 of 12 Old 10-15-2013, 12:13 PM
Maineshootah
So, I am assuming with this setup, and using standard wiring colors,
Yellow and white (Left turn and stop)
Green and white (right turn and stop) to each respective rear brake light assembly for the bulbs, then ran the cable to a standard 4 plug up at the front of the jeep?
I just got back from a 800 mile flat tow with the external Harbor Freight mag mounted lights, and while they "worked" to fulfill the letter of the law, there were not very bright. I REALLY like the idea of containing it all IN the jeep rear brake lights, with just a plug in cable hanging out up front for use with the towing vehicle.
Nice.
I guess my YJ Is my midlife crisis therapy.....
My 95 YJ cross country (AZ to ME) frame swap thread.
http://www.jeepforum.com/forum/f22/maineshootahs-cross-country-95-yj-build-1487587/
Maineshootah is offline
post #10 of 12 Old 10-15-2013, 01:09 PM
jbolty
jbolty's Avatar
Yup, standard colors. I ran the wire inside the frame as far as I could then outside with an old piece of air hose as a cover. I tow with more than one vehicle so I got them all set up to industry standard.
Funny thing with the harbor freight tow lights, I have several sets and without exception the bulb sockets are in backward. Take out the bulb, push up the wire to release the flat piece at the bottom of the socket, turn one half turn and pull it back down. The original assembly has the brighter side of the bulb wired to the running lights and the dimmer side to the turn/brake; you could barely see it when the brake or turn was on.
jbolty is offline
post #11 of 12 Old 10-15-2013, 01:19 PM
Scott1990
Flat towing
I just want to put this out there Be careful doing this with a off road trail rig. I was coming back from Badlands in Attica In and I was pulling my YJ with a 02 GMC crew cab Duramax Diesel and about 65 mph the left front wheel bearing failed and turned the Jeep wheel to the left and sent me in to a left slide and about flipped both of them over. I am so glad no one was beside me cause I would of took them out with me..... Just be careful out there.
Scott1990 is offline
post #12 of 12 Old 10-15-2013, 01:25 PM
Maineshootah
Great info thanks!
I will check out the lights, I have a feeling mine is the same way, they are very dim.
Love the protected mount on the jeep as well.. I might do that as well.
new vss..what is the wiring setup kelti819 YJ Wrangler Technical Forum 0 10-26-2010 08:54 AM
OBA setup/wiring help. Anonymity TJ Wrangler Technical Forum 10 03-09-2010 08:50 PM
Flat Tow - Ultimate Setup? DiscoBayJoe JK Wrangler Technical Forum 2 09-24-2007 12:26 PM
Flat Tow wiring udamann TJ Wrangler Technical Forum 7 09-03-2004 06:59 PM
Flat Tow Wiring - what do you use? powerchuck TJ Wrangler Technical Forum 3 04-05-2004 09:15 PM
