wiring - JeepForum.com
post #1 of 40 Old 02-27-2013, 03:44 PM Thread Starter
linusb
wiring
I've had my Jeep 3 years and the PO had a mess with the wiring under the dash. I haven't helped any as I've tapped into some random hot wire to power the switch for my on board air, as well another circuit for sound bar, CB, and winch switch.
I want to clean this all up but don't know where to start. What's the correct way to get a 12 volt feed that is switched on with the ignition? and how many accessories should i be running off of such a feed?
THere is a 5 prong connector under dash that wasn't hooked to anything. Two of those prongs have power with ignition so I have one powering the soundbar and one powering the winch switch. My CB is left powerless until I get this figured out.
Also, typical toggle switches you buy have 3 prongs. Is the purpose of the 3rd prong to serve as a jumper to another accessory switch?
I'd really like to put in a CJ dash at some point, but that's probably a ways down the road.
The previous owner has all kinds of crap tapped in to various wires which I don't know what they'd be for because there are no accessories at this point in time except what I've mentioned.
The previous owner did have an after market stereo which wasn't wired in at all and there was also an after market cruise control that I took out.
I don't have a stereo head unit, just the soundbar which has a microjack input that I plug into my iphone for tunes.
With the way the wiring looks, I'm amazed that everything works.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #2 of 40 Old 02-27-2013, 05:25 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
For switched power, you can run a lot of switches off of one wire. Those switches would then turn on relays and power all of the electrical goods you have installed. For the cb, you should use the 12v switched wire directly to a relay which powers your radio.
Edit: My post is from memory. I do not have any saved info with me so I apologize if any is wrong.
Michaelgoesrawr is offline
post #3 of 40 Old 02-27-2013, 05:39 PM
bigbossd1030
I put in an aux fuse panel under the hood for this specific reason, adds 6 fuses.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #4 of 40 Old 02-27-2013, 05:43 PM
Michaelgoesrawr
Good point.
post #5 of 40 Old 02-27-2013, 06:05 PM Thread Starter
linusb
So the source I have found that comes on with ignition, should I use that to source an auxiliary fuse box? From the fuse box I could power the following toggle switches:
1) on board air (stock a/c compressor)
2) winch (in/out/off)
3) secondary switch for #2 to prevent accidental winch activation
Then I need my soundbar and cb wired without toggle switches straight to fuse box.
I don't understand where the relays come in. Aren't these accessories low enough amperage to just flow power to the load directly through the toggle switch?
What about running a heavier gauged wire from battery to a master accessory switch to fuse box to the other switches and accessories listed above, requiring me to make sure I turn off that switch each time I leave vehicle lest I drain battery.
I have a very minimal understanding of electrical design so any education is helpful to me. How about the switches, is that third prong used optionally to power an adjacent switch?
linusb is offline
post #6 of 40 Old 02-27-2013, 06:21 PM
Michaelgoesrawr
The winch and winch power switch are low amps and don't need a relay. The OBA should have a relay and a pressure switch wired into as well. I think the compressor clutch may be to much amperage for a switch. Plus you can then run smaller wires to it through the firewall.
As far as the cb, I don't know what amperages they take. So you could run it on a switch without one of you wanted, probably. Edit: Just realized you said straight to fuse box with this and your sound bar. IMO you would need to run a heavier gauge wire from the battery for this.
As for the third connector I'd say it's a ground if it's the lighted one you told me about.
The best way to ensure you turn off all of your stuff at the same time would be to run a fusebox powered by a keyed ignition source. That way, when the Jeep is off, so is everything else. I'd power it through a relay, but that's just me. I guess I really like the idea of everything on relays.
post #7 of 40 Old 02-27-2013, 06:30 PM Thread Starter
linusb
Thanks! The OBA does have the pressure switch in the circuit. Putting in a relay for that sounds like a good idea now that you mention it. I'm running 12 or 14 gauge wire to it currently. I'm not sure what amperage the switch is rated for.
linusb is offline
post #8 of 40 Old 02-27-2013, 06:33 PM
Michaelgoesrawr
That is massive wire to a switch in the cab. Stick a relay in the system and you can run a much smaller wire 16-18ga(if I remember correctly). It's safer too because relays require a small amount of power to be activated so instead of a high amount of amps you get a tiny amount.
post #9 of 40 Old 02-27-2013, 06:36 PM
Michaelgoesrawr
Also, I apologize if I don't make any sense. I'm on my phone and having a hard time getting my thoughts across.
post #10 of 40 Old 02-27-2013, 06:36 PM Thread Starter
linusb
This is what I want. I'm just unsure about the right way to get the keyed ignition source. Just find a random unused source like I've done?
linusb is offline
post #11 of 40 Old 02-27-2013, 06:43 PM
Michaelgoesrawr
Found a computer at school!
A lot of people use the keyed radio source and that is my plan as well when it comes time for me to add all of my goods. (Don't worry, I have done a lot of reading on the subject!)
In your shoes, I would use the keyed radio wire to power a relay which would then power a fusebox that would allow you to run things of your choosing. It can be mounted in the cab or engine bay, your choice.
I dug up this article to maybe help explain relays and how to wire them.
http://www.jeepforum.com/forum/f20/w...ations-378268/
Edit: The cigar wire as pointed out below is good too.
post #12 of 40 Old 02-27-2013, 06:46 PM
bigbossd1030
No, what you want to do is go through your original fuse box, if you want ignition activation. I suggest going through your cigar lighter. This way, there is no draw on any other system component, plus it's already fused, and upping the fuse as per the device being powered is possible. My aux fuse panel is hooked directly to my battery as it is hooked up to my alarm, under body flood lights and my winch cam. So all of these I normally would like to run with the jeep off. Not so much the cam. I personally like 16g wire for most everything. Oh and I have my cb hooked up to my capacitor for my amp. It gets a bit staticky while capacitor is charging lol.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
I am on channel 33.
post #13 of 40 Old 02-27-2013, 06:46 PM Thread Starter
linusb
Thank you so much-Very helpful!!
linusb is offline
post #14 of 40 Old 02-28-2013, 12:40 AM
Michaelgoesrawr
Feel free to email or text me if you want. I may be of some assistance.
post #15 of 40 Old 02-28-2013, 11:30 AM
yjkid4life
so im rebuilding my dash on my 90 yj and i have a question i want to install all new guages and ive searched over the forums and alot of people are saying to use autometer guages. ok. now im great when it comes to wiring things but i just wanted to no the stock harness that plugs into the stock guage cluster can i just tape that off and tuck it out of the way or is there i diagram i can get to tap into those wires instead of running new wires to each sending unit/sensor. I have experienced electrical problems in the past on chrysler esp. that when u disconnect some harnesses and try and run vehical you will get a short to ground and motor wont start i was wondering if i would face a problem like this? i wouldnt mind just running nice new wire anyway to each sending unit/sensor... please help
yjkid4life is offline
