Wipers won't go all the way down?? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Wipers won't go all the way down??
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 11-15-2009, 12:20 AM   #16
lclark2074
max with all your skills iam suprised youhavent fix that yet
night crew 226
http://www.jeepforum.com/forum/f12/f...l-box-1471348/
lclark2074 is offline   Reply With Quote Quick reply to this message
Unread 11-15-2009, 12:21 AM   #17
dodger889
Well the good thing is they are the same between xj and yj.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote Quick reply to this message
Unread 11-15-2009, 12:31 AM   #18
Hussler
1992 XJ Cherokee
friends yj does that. i find it distracting
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline   Reply With Quote Quick reply to this message
Unread 12-02-2009, 01:28 PM   #19
Spetsnaztico
1987 YJ Wrangler
mine won't park either and the inspector will not pass my jeep until they do. Does anyone have a diagram of the relays in an '87 YJ? I'd like to check if the relay is faulty before replacing the motor.
USN Jeep Club Hull #130
Spetsnaztico is offline   Reply With Quote Quick reply to this message
Unread 12-02-2009, 02:39 PM   #20
MAX_Xj
MAX_Xj's Avatar
1998 4dr XJ
MAX_Xj is offline   Reply With Quote Quick reply to this message
Unread 12-02-2009, 02:40 PM   #21
MAX_Xj
MAX_Xj's Avatar
haha sorry had to play with the smilies couldnt help myself but yea yjs all have intermintant problems for the most part soon as my jeep hit 180,000 wipers started acting up
1998 4dr XJ
Unread 12-02-2009, 04:12 PM   #22
ziebartrob
I'm not wishing it upon you, but that is what happened to mine on the 91 just before the wiper motor went out. They started to park a little too high for about a month or so and then just quit working. I never did fix it, just put a lot of aquapel on the w/s:-)
Originally Posted by Mymmars
when your start to anthropomorphise your jeep into somthing above a dog and below a hooker
ziebartrob is offline   Reply With Quote Quick reply to this message
Unread 12-02-2009, 04:38 PM   #23
ZeroGravity
The wiper arms pop off the splined stubs very easily with a wide pry bar or a screwdriver. If they are 60-75* like you say, maybe they were removed and installed incorrectly.
91 YJ
98 XJ
2 door love
The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
ZeroGravity is offline   Reply With Quote Quick reply to this message
Unread 12-03-2009, 10:01 PM   #24
dodger889
No relay it uses a electrical contacts ( wipers in the motor. You can check them by opening the part the has the control arm. There is a set of contacts with a wiper inside you can move the wiper part just a little and should work again like new or replace the complete motor .
Unread 12-04-2009, 04:17 PM   #25
roadking951
anyone know where the intermiate relay is????
roadking951 is offline   Reply With Quote Quick reply to this message
Unread 12-04-2009, 10:31 PM   #26
dodger889
under the dash close to the steering column.
Unread 12-04-2009, 10:37 PM   #27
roadking951
ok ill take a look tomorrow ty
Unread 12-04-2009, 11:07 PM   #28
Spetsnaztico
1987 YJ Wrangler
Thanks Ill check it out.
Unread 12-05-2009, 03:45 AM   #29
1bad92yj
What could it be if the delay didnt work or they didnt park and the delay module has been replaced?
1bad92yj is offline   Reply With Quote Quick reply to this message
Unread 12-05-2009, 05:29 AM   #30
dodger889
You can bypass the delay controller by removing it. The connectors will plug into each other.
