Wipers took a dump - JeepForum.com
post #1 of 6 Old 10-21-2011, 03:12 PM Thread Starter
KBoltz
Wipers took a dump
And of course, when it is frickin raining. Great.
The two outer plastic nuts split as well. I have epoxied them for the time being. Can this be repaired without having to tilt the windshield? I have a bloody hard top on, so that will be a major biatch.
Any help would be greatly appreciated. And to think, Sunday I am going to replace all the u joints and the rear diff cover. One weekend off every four weeks, and the Heep takes the majority of the time.
Since I have to drive 20 miles to where I am replacing the u joints (which is warm and dry garage a friend is graciously allowing me to use) and it will be raining all weekend, I really need to get this fixed pronto.
KBoltz is offline
post #2 of 6 Old 10-21-2011, 05:12 PM Thread Starter
KBoltz
Anyone know the part number off hand for the outer plastic nuts for the wiper assembly? The ones that hold the assembly to the windshield frame?
KBoltz is offline
post #3 of 6 Old 10-22-2011, 10:32 AM Thread Starter
KBoltz
It wouldn't matter - I checked with MOPAR online - Jeep discontinued that part.
Has anyone had the same problem? I would think as old as our YJ's are getting that this would be occurring more frequently.
I am going to try the good old hardware store and see if I cant find a regular nut and washer to fix this.
KBoltz is offline
post #4 of 6 Old 10-22-2011, 12:48 PM
ads
http://www.dontfearthejeeper.com/ should have it, though you would need to check with them for stocks.....
they have nice illustrations of all the parts so you can make sure you get the bits you need - but it seems the wiper pivot and body connection comes as a whole kit for about $54.
From trying to find the issues with my non-working wipers I think you'll have to drop the windscreen to get to it, but I may well be wrong
1995 YJ - mostly stock at current. 31" Procomp AT, rebuilt stock springs with added leaf (2.5" lift), OME shocks & stabiliser, 20gal tank mod, air box de-restricted, afe wet filter, soundbar, new distributor/rotor & stuff, TBS.
ads is offline
post #5 of 6 Old 10-22-2011, 01:49 PM Thread Starter
KBoltz
I just called them - they let the Jeep guy go, thanks economic turn down. No bueno on the part. I am going to rip the frame apart tomorrow - there goes replacing the u joints. They'll keep for another month.
KBoltz is offline
post #6 of 6 Old 10-23-2011, 07:56 PM Thread Starter
KBoltz
Fixed it - it seems when I installed the linkage for the assembly, I put the delrin bushing on backwards where the linkage hooks up to the motor assembly. Oops.
So, now I have wipers again - and replaced the steering stabilizer and the rear diff cover as well.
The sun actually came out today here in Vancouver. What a novel thing.
KBoltz is offline
just got a tj!!! Intermittent wipers do not work but low and high wipers do justme TJ Wrangler Technical Forum 1 09-06-2011 06:29 PM
My ax5 Tranny to DUMP JB73 TJ Wrangler Technical Forum 1 07-12-2011 09:41 PM
D35 just took a dump on my chest. Now what? MattSink TJ Wrangler Technical Forum 37 10-31-2009 02:13 PM
exhaust dump bubbakutz TJ Wrangler Technical Forum 1 08-31-2005 03:11 PM
Do I NEED to dump the D35? BillR TJ Wrangler Technical Forum 16 06-24-2005 03:46 PM
