Wipers - JeepForum.com
post #1 of 18 Old 06-22-2013, 09:12 PM Thread Starter
Noclrnce
Wipers
Got quite a bit of rain today and I discovered my wipers don't work. It's a 95 yj what do I need to check besides the fuse?
Noclrnce is offline
post #2 of 18 Old 06-22-2013, 09:52 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Grab a test light and check the power at the fuse box. Then test the relay.
Anticanman is offline
post #3 of 18 Old 06-23-2013, 10:43 AM
wendell
1987 YJ Wrangler
Yep, always start with the easiest, the fuse.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #4 of 18 Old 06-23-2013, 11:43 AM Thread Starter
Noclrnce
Ok I checked all fuses under the dash and they are all good. Wipers don't appear to be marked on the cover so I checked them all
Noclrnce is offline
post #5 of 18 Old 06-23-2013, 01:09 PM
deathtrap
Wipers are on the 5.5A circuit breaker in the under dash fuse panel.
deathtrap is offline
post #6 of 18 Old 06-23-2013, 02:51 PM
Old4X
1990 CJ7
Pull the intermittent wiper control box out. It has in and out harness connectors. The 2 connectors will plug into each other.
If the box is bad (most are at this age) your system will have off, low and high but no intermittent.
The solder work in these control boxes is sloppy, you can easily repair them once you drill the rivets out.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 18 Old 06-23-2013, 04:31 PM Thread Starter
Noclrnce
Where is that box located? I'm not sure what I'm looking for exactly
Noclrnce is offline
post #8 of 18 Old 06-23-2013, 06:00 PM
Old4X
1990 CJ7
It is shaped like a pack of cigerettes, but 1/2 the size.
As you sit in the driver seat it is behind the dash about where your left knee is. It is often velcroed to a sheet metal bracket. It has a plastic case, most are black, but white and green have also been seen
Old4X is offline
post #9 of 18 Old 06-23-2013, 06:29 PM Thread Starter
Noclrnce
Just pulled the module out and plugged the connectors together and still nothing. The washer pump works either way.
Noclrnce is offline
post #10 of 18 Old 06-23-2013, 07:35 PM
Old4X
1990 CJ7
Sounds like it is time to get your multi-meter out and drop the windshield. Start at the ww motor and work your way back till you find the problem.
If you have power at the mptpr and a good ground, motor is bad.
Old4X is offline
post #11 of 18 Old 06-23-2013, 08:09 PM Thread Starter
Noclrnce
Thanks for all the help. I will tackle it this week.
Noclrnce is offline
post #12 of 18 Old 06-23-2013, 09:20 PM
Rich G
Drop the windshield, mine has broke the linkage twice.
See if you can hear it running.
Rich G is offline
post #13 of 18 Old 06-28-2013, 08:20 PM Thread Starter
Noclrnce
Forgot I posted this already. I put a motor in yonite and the wipers now work. Only problem is they lean toward the driver side. Did I do something wrong? It looks funny lol
Noclrnce is offline
post #14 of 18 Old 06-29-2013, 06:04 AM
Old4X
1990 CJ7
Just reposition the wiper arms on the nubs.
Old4X is offline
post #15 of 18 Old 06-29-2013, 07:58 AM
fromme
fromme's Avatar
1977 CJ7
Sounds like you have the linkage indexed incorrectly on the motor shaft.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
