wiper switch - JeepForum.com
post #1 of 3 Old 05-26-2011, 03:51 PM Thread Starter
91yjrig
wiper switch
just curious if any one has replace the column wiper switch to onther location or how to fix it basically only has HI it wont intermittent. it almost doesnt click till you are at the high position just curious
thanks
91yjrig is offline
post #2 of 3 Old 05-26-2011, 06:18 PM
dancytron
Yes, put down the windshield and the motor is right there.
Get a wiring diagram or search this forum to find out which wires are which.
Cut all the wires and rewire it/run all new wires properly fuse them to a 3 position switch (on-off-on) switch on the dash.
You'll lose intermittent and the park function if you have those now.
Tape up wires you don't use.
Don't try to tap into wires in the middle.
dancytron is offline
post #3 of 3 Old 05-26-2011, 07:38 PM
EZAces
If you wire it use a wiper switch from your parts store. If I rember right there is one wire that is hot all the time for park. to replace the factory switch you have to pull the stearing wheel.
EZAces is offline
hey guys wondering how to wire lights to the switch by the rear wiper switch... help kingator TJ Wrangler Technical Forum 1 09-26-2010 08:00 PM
Somebody still have that wiper switch? martells2 YJ Wrangler Technical Forum 1 08-24-2010 07:43 PM
wiper switch sandman'sjeep YJ Wrangler Technical Forum 3 03-03-2007 03:24 PM
wiper switch ? flashzone YJ Wrangler Technical Forum 1 05-24-2006 02:16 PM
Wiper Switch? DaSham58 YJ Wrangler Technical Forum 1 03-27-2006 07:28 PM
