wiper questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > wiper questions
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineEngo winches available at www.rockridge4wd.com! Free shipp
Unread 12-20-2005, 11:35 AM   #1
toplessjeep
wiper questions
Ok this is another stupid question, but I haven't had my Jeep long and I am still learning. I need to remove my windshield wiper arms. How do they come off? I don't see a cap to remove for a nut. Am I just having trouble getting the cap off, or is there a pin that holds them on?
toplessjeep is offline   Reply With Quote
Unread 12-20-2005, 12:01 PM   #2
wolf3902
There is sort of a hooked tab that closes down over the lip of the splined shaft. You need to push the tab back as you pull. The tab sticks out..or inward. On the side that the arm goes out to.
The o's are the splined shaft...the lines are the clip
oooo WIPER ARM GOS OUT THIS WAY...
oooo l
oooo l
ooo_ l
Pry out here>>>>>
God I hope that makes sense
'93 YJ 2.5 Jasper; 5 speed
All stock, waiting to be reborn.
6/19/05 ...2" BDS suspension lift...the rebirth has begun!!!
ONE NATION, UNDER G O D
Support It, or Leave It!
wolf3902 is offline   Reply With Quote
Unread 12-20-2005, 12:01 PM   #3
jeffy
The arms are splined so you need to pull them straight up. Using a screwdriver helps get them started.
www.4BangerJP.com
A Pitiful RigRater Score: 789RRv1.0
jeffy is offline   Reply With Quote
Unread 12-20-2005, 12:34 PM   #4
EABiker
As I recall, there is a small hole in the wiper arm; pull the wiper forwards off the windshield, place a nail or something similar in the hole, release the wiper arm, then pull/wiggle the arm off of the post.
EA
EABiker is offline   Reply With Quote
