Wiper linkage bushing HELP!!!!! - JeepForum.com
post #1 of 11 Old 01-21-2011, 05:30 PM Thread Starter
chileanguy
I am looking for the pictured plastic bushing that connects the motor to the drive arm. I can't seem to find this anywhere. Many thanks!
chileanguy is offline
post #2 of 11 Old 01-22-2011, 06:45 AM
HayWrangler
You have two choices,
1. Buy a new arm including the bushing - about $40 if I recall correctly.
2. Go to autozone like I did and you will find a generic windshield wiper bushing selection in the "HELP" section. In the pack a couple of the bushings look very similar to the original bushing but need to be modified with a razor blade.
It took me two goes at it but so far so good I could not see paying the $40 odd dollars for a plastic bushing.
Regards
HayWrangler is offline
post #3 of 11 Old 01-22-2011, 08:51 AM
mightybg
Autozone or Oreilly's will have that in the pack I'm pretty sure if it is the same as the bushing at the wiper transmission on the passenger side and the arm to that side. the gray one that is on the ball joint on the drivers side wiper transmission is the one I could not find and had to buy a replacement linkage assembly form eBay to get. it is slightly bigger than the others.
mightybg is offline
post #4 of 11 Old 04-08-2013, 07:46 PM
hooks
Regards
Hey man I have a friend with a 1994 and having this same issue . He was wondering about modifying the washer and how to . This is old I c but thought maybe u cld shed some light
The Brotherhood of Bikers lives by the code of the three B's: Bikes, Beer, and Booty.
hooks is offline
post #5 of 11 Old 04-15-2013, 08:31 PM
Blackhawk83
I welded a lawnmower tierod end onto my linkage and did away with plastic bushings all togeather. It souds trashy, but it works awesome. Ill try to find a pic of it.
Blackhawk83 is offline
post #6 of 11 Old 04-16-2013, 11:48 AM
jserna
1987 YJ Wrangler
Thanks for the ideas. I am in the same boat too.
jserna is offline
post #7 of 11 Old 04-16-2013, 12:02 PM
hooks
Lol,awesome please do
hooks is offline
post #8 of 11 Old 02-23-2014, 09:41 PM
Blackhawk83
It has been to long I'm sure, but it may help someone.
post #9 of 11 Old 04-29-2014, 10:41 PM
dukeryder
I can't believe they don't sell a wear item part like this I'm not really understanding how that homemade job above functions...
I just replaced my windshield frame and I'm having a of a time trying to get my wipers to work and in the process of messing with the linkage I somehow got this bushing buggered up, instead of popping it off the ball I popped it out of the linkage and now it won't stay in the linkage arm. I also messed when I took the linkage out of the old frame by removing the nut off of the wiper motor arm. I did reinstall it in what I believe to be the correct orientation, but (before I buggered up the bushing) would have the linkage bind up when I bolted the motor tightly to the frame, if I had the motor loose the wipers would cycle. not really sure what the heck I need to do to get them working correctly...
dukeryder is offline
post #10 of 11 Old 04-30-2014, 03:18 AM
clintlight27
Like others have said I had luck with the generic pack of bushings from autozone. With ten minutes and a razor blade I was able to fab one up that works perfectly.
clintlight27 is offline
post #11 of 11 Old 04-30-2014, 06:39 PM
Old4X
1990 CJ7
The lack of this bushing goes back at least to the AMC days. I remember folks getting real cheesed about having to buy a 15 dollar part (price back in the day) just to get a 10 cent bushing.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
shifter linkage bushing mpd2434 TJ Wrangler Technical Forum 4 07-22-2009 05:44 PM
4wd shift linkage bushing worn out?? TJRanger TJ Wrangler Technical Forum 12 10-27-2008 08:47 PM
Transfer Case Linkage Bushing Replacement seabass2020 TJ Wrangler Technical Forum 1 07-16-2008 08:41 AM
clutch pedal to linkage bushing trapster12 TJ Wrangler Technical Forum 3 11-15-2007 07:26 AM
Linkage Bushing? dcafaro YJ Wrangler Technical Forum 1 09-01-2004 03:47 PM
