Wiper control module - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Wiper control module
1 Ton Heavy Duty Steering Upgrade Kit. New and Improved dStainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 07-02-2014, 08:16 PM   #1
areyes0429
I have a 93 wrangler. Can someone tell me where the module is located in the jeep. They are not parking after turn off. Failed state inspection. Help
areyes0429 is offline   Reply With Quote
Unread 07-02-2014, 08:17 PM   #2
Michaelgoesrawr
Michaelgoesrawr's Avatar
Under the dash. Black box.
Michaelgoesrawr is offline   Reply With Quote
Unread 07-02-2014, 08:22 PM   #3
areyes0429
Could you tell me is it on the drivers side or passengers side. I have looked and don't see it. Is it easily accessed or do I need to remove any panels. Thanks for any info provided.
Unread 07-02-2014, 08:51 PM   #4
YJ4LIFE
it might be missing. I threw mine away once thinking it was part of an old alarm system. I got a new junkyard one for $5. google "jeep wiper control module." It should be somewhere under the dash near your steering column
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline   Reply With Quote
Unread 07-02-2014, 09:02 PM   #5
areyes0429
Ok thanks that may be the case. I will buy a new one and plug it in. I recently changed the turn signal switch and I don't recall a black box. Thanks for the information.
Unread 07-02-2014, 11:41 PM   #6
timatoe
Far left side, held on with a big piece of velcro.
timatoe is offline   Reply With Quote
Unread 07-03-2014, 07:02 AM   #7
jerresredyj
jerresredyj's Avatar
Not sure if your 93 is the same but when my 89 wipers wouldn't park it was the switch in the column. Did yours park before you changed the turn signal switch?
jerresredyj is offline   Reply With Quote
Unread 07-03-2014, 09:07 AM   #8
Que89YJ
Good luck finding a new one. Just pull the module and plug the 2 sides together. The module is only for intermittent wipe.
Que89YJ is offline   Reply With Quote
Unread 07-03-2014, 02:13 PM   #9
bpounds
bpounds's Avatar
I can't say for sure on Jeep, but usually wiper parking is part of the wiper motor.
Mine don't park either, and I don't have a module. No intermittent function on mine.
Man, that is a damned strict state inspection.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline   Reply With Quote
Unread 07-03-2014, 02:52 PM   #10
XJ93
Yeah new ones are obsolete, I pulled the one out of my old 89 XJ and it works perfectly in my 95 YJ even though interchange says otherwise. I like having the pulse...sometimes.
XJ93 is online now   Reply With Quote
Unread 07-03-2014, 02:57 PM   #11
Delawdude
Delawdude's Avatar
Just time it and turn them off at park location
One of the wires from the column is for park--grab a chiltons manual and it will have the wiring schematic
Delawdude is offline   Reply With Quote
Unread 07-03-2014, 07:43 PM   #12
JMickey
Just for the record, the box held in with Velcro is for wiper delay only. You can unplug both sides and put the connectors together without the box. You won't have delay but you will still have hi and low. If it still doesn't park, then it's the park switch in the motor.
JMickey is offline   Reply With Quote
Unread 07-03-2014, 08:03 PM   #13
Rus03ty
2010 JK Wrangler
Rus03ty is offline   Reply With Quote
Unread 07-03-2014, 08:31 PM   #14
Rus03ty
2010 JK Wrangler
Unread 07-03-2014, 08:32 PM   #15
Rus03ty
2010 JK Wrangler
