Wiper Arm Removal - JeepForum.com
post #1 of 12 Old 03-10-2010, 03:11 PM Thread Starter
ruth
Wiper Arm Removal
Hello:
The plastic retaining nut under the windshield wiper arm on my 93 YJ has cracked. Can anyone tell me how to remove the wiper arm to access the nut ? Jeep says that the nuts cost $13 each ( quite a bit for a piece of plastic), but I have to remove the arm first. I've read about sticking a pin through the hole in the side of the arm but there doesn't seem to be any mechanism to depress, etc. The base of the arm doesn't seem to have any tab to pull (another method I've read). I'm confused and don't want to pry the arm off only to find that I've destroyed something and can't re-attach it.
Any assistance will be appreciated. Thanks.
ruth is offline
post #2 of 12 Old 03-10-2010, 03:19 PM
sebastian22
the entire arm pulls straight off. you can gently pry it with a small flathead.
95 Black YJ
sebastian22 is offline
post #3 of 12 Old 03-10-2010, 03:20 PM
tractor1
1979 CJ5
To remove the arm you need to pull it straight off. It on a spline use a little pry bar to help.
tractor1 is offline
post #4 of 12 Old 03-10-2010, 04:38 PM
njmrenegade
pull the wiper as far away from the windshield as you can, then there is a hole that is on both sides (top and bottom) of the wiper arm, put a pin in the hole and let the wiper go, you should be able to pull it off then, i can get pics tomorrow
njmrenegade is offline
post #5 of 12 Old 03-10-2010, 04:40 PM Thread Starter
ruth
Thank you. I'll await the pics.
ruth is offline
post #6 of 12 Old 03-11-2010, 02:36 PM
timoteo1234
like was said before. I just used a small flathead to remove it.
timoteo1234 is offline
post #7 of 12 Old 03-11-2010, 07:13 PM
njmrenegade
there is a hole on the underside just like, you pull it out like the last pic and put a pin through both holes, release the wiper arm, don't put pressure, and it should just slide off
post #8 of 12 Old 04-02-2010, 08:38 PM Thread Starter
ruth
Thanks so much for the pics. I haven't had time to get to the Jeep yet; but, I really appreciate your help. Thanks again.
ruth is offline
post #9 of 12 Old 07-29-2012, 09:15 PM
caoboy
This should be stickied in the YJ FAQ's thread! Bumping this because it helped fix my _ \ looking wipers.
caoboy is offline
post #10 of 12 Old 07-29-2012, 10:01 PM
G30SFF250
Not the wiper arm disconnect I was thinking of.
I would rather have a broke Jeep, than no Jeep at all.
G30SFF250 is offline
post #11 of 12 Old 11-20-2014, 10:51 AM
dodge1980
I have a 93 jeep and I need to get the big plastic thing off to fix the driver side wiper how do I get that off.
dodge1980 is offline
post #12 of 12 Old 11-20-2014, 12:19 PM
fishadventure
A) what is the big plastic thing?
B) the OP posted this in 2010 and the pin in the hole detailed by the pics is how to do that part. Don't just pry it off because that may break something if you are unlucky
C) post a pic because we can't see the plastic thing that you see in your head
D) is anyone else fascinated that the OP joined in 2003 but only posted 5 times to 2010?!
shackles or D rings?
wrong words brake the web
cranking IS turning over
fishadventure is offline
Wiper arm removal sjwrangler YJ Wrangler Technical Forum 5 02-17-2009 12:12 PM
Wiper Arm Removal? yjcrawler YJ Wrangler Technical Forum 6 07-19-2007 07:49 PM
Wiper removal rob1525 TJ Wrangler Technical Forum 5 04-27-2007 01:16 PM
Wiper Removal Nater018 YJ Wrangler Technical Forum 6 06-24-2006 02:19 PM
Wiper arm removal RipcordAFF TJ Wrangler Technical Forum 12 11-02-2005 12:45 PM
