Quantcast winter prep for heat - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > winter prep for heat
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 10-28-2008, 12:24 PM   #1
GRN_BEAST95
anyone got any ideas on how to get better heat and keep the engine warm. mine doesnt even warm up at all. even when im driving so i dont get heat. any ideas on how to beef up the heating???
1995 YJ emerald green
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Green Jeep member 153
Originally Posted by yellojeeper View Post
Guam. I spent a week there one night.
GRN_BEAST95 is offline   Reply With Quote
Old 10-28-2008, 12:30 PM   #2
mylogylo
Did you or maybe the PO remove the thermostat? Mine would not warm up and I had no heat. I found that the PO removed the thermostat.
mylogylo is offline   Reply With Quote
Old 10-28-2008, 12:42 PM   #3
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Change your tstat out for a new 195* unit. That should get your engine warmed up if nothing else is wrong.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 10-28-2008, 12:44 PM   #4
MLJeeper
MLJeeper's Avatar
I use a piece of cardboard over the radiator, no really but im ghetto like that
Your limited slip differential sucks.
MLJeeper is offline   Reply With Quote
Old 10-28-2008, 12:57 PM   #5
Tkamplin
I think my heater core might be plugging. It'll heat ok, then BAM freezing air and my temp guage will spike. then it goes back down again. Kinda weird.
Heater cores are always suspect when you're cold.
'95 YJ, 2.5/AX-5, 1" Daystar BL, 2" BDS leafs, 33x12.50 Wrangler duratracs, Aussie locked front.
Tkamplin is offline   Reply With Quote
Old 10-28-2008, 12:58 PM   #6
xeroid81
The thermostat is a cheap addition whether it's the prob. or not. Start there,along with a system flush if poss. Then check your mix to make sure it's 50/50 water to anti-freeze. That should do it for you. Good luck!
xeroid81 is offline   Reply With Quote
Old 10-28-2008, 02:33 PM   #7
brewer
When I bought my jeep, the heater was near non-existent. I swapped out the thermostat and still had nothing. I was puzzled by it, but dealt with the cold initially. Then one weekend, I went on a camping trip in the mountains and froze my butt off. I also encountered a ton of water on the trip that essentially soaked my interior because I also had a windshield frame leak. (That was another issue) Anyway, when cleaning up the water mess, I was toweling down the inside and accidentally pushed a metal lever in front of my blower motor. It was mostly rusty and difficult to move, but when I bumped it, it moved some parts. I had no clue what I was doing back then - but have since learned the lesson of what it was.
Long story short, in front of the blower motor on the passenger side (near the feet) was this metal rod that was rusty. Pushed the rod downward and Voila! Heat! Couldn't believe it!!
Girlfriend was extremely choked that I discovered this AFTER the trip, since she nearly got Pneumonia from the cold water leaking on her feet!!
I'd check this little rod lever if I was in your shoes before you do anything else based on my learned experience.
Good luck to you regardless
Beauty is but a lightswitch away :D
brewer is offline   Reply With Quote
Old 10-28-2008, 02:38 PM   #8
turtlerace
Instant Gator
turtlerace's Avatar
1982 CJ7
I think you might have the wrong forum.
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
2006 Liberty Sport CRD
1979 J10 LWB
turtlerace is offline   Reply With Quote
Old 10-28-2008, 06:18 PM   #9
GRN_BEAST95
i have the cardboard in front of the radiator. i painted it black so u cant really tell tho. i will deffinatly check out my thermostat. im pretty sure its not there or stuck open. thanks for the tips
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Old 10-28-2008, 06:53 PM   #10
noodle9
my 94 did the same thing when I bought it. I flushed the heater core with a garden hose. I held it up to the heater core inlet and outlet and flushed it out both ways. Then I held it tight to the outlet side again to get the full hose pressure into the core, and alot of crap came out of the other end. After refilling the system, the heat worked great. Good luck.
noodle9 is offline   Reply With Quote
Old 10-28-2008, 07:59 PM   #11
GRN_BEAST95
i think i need to work on getting my engine warm first then maybe my heat will work.
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Old 10-28-2008, 08:05 PM   #12
turtlerace
Instant Gator
turtlerace's Avatar
1982 CJ7
Do you have the stock fan or an electric? Ever since I have installed my electric fan, I can't get my engine to heat up with the heater on. Never have figured out why.
1979 J10 LWB
Old 10-28-2008, 10:42 PM   #13
GRN_BEAST95
stock fan
4" RC lift & 2" BL
33x12.5x15 BFG AT's
Old 10-29-2008, 05:58 AM   #14
rustywrangler
Stock fan should not be a problem. Have been running jeeps for over 12 years now with nothing but stock cooling systems and never had a problem with heat.
Old 10-29-2008, 07:03 AM   #15
mark12010
mark12010's Avatar
Not to hijack this thread but It may or may not be relevant. What about an engine block heater? On that note does anyone know where I can get one for my 90 yj 4.2?
mark12010 is offline   Reply With Quote
Glock Forum
