Windshield Wipers: Not working! - JeepForum.com
post #1 of 12 Old 02-26-2010, 11:45 AM Thread Starter
Lambo3244
Hey fellas,
Driving down the freeway, in the rain, and the wipers just stop working right in the middle of the windshield. Thankfully, I had Rain-X on the windshield and gave me a clear line of site down the road, lol. Got to school, parked the Jeep, and shut her off. After about 10 minutes of waiting, the wipers worked! The rain stopped and I went and enjoyed the rest of my day.
But then, today, the wipers stopped working AGAIN, in the rain, on the freeway.
What is going on here? Maybe the motor? Where should I look first?
Lambo3244 is offline
post #2 of 12 Old 02-26-2010, 11:59 AM
havasu
On permanent vacation
havasu's Avatar
My first guess is that your wiring leading to the wiper motor has shorted out, usually from a pinched wire where you collapse your windshield. Drop it down and inspect the wires.
havasu is offline
post #3 of 12 Old 02-26-2010, 12:02 PM
SteveJcoYJ
the water probably shorted out a wire somewhere
and fwiw, if you have rain x on the windshield your not supposed to use your wipers, it defeats the purpose
SteveJcoYJ is offline
post #4 of 12 Old 02-26-2010, 01:33 PM Thread Starter
Lambo3244
Thanks fellas. I will check it out and get back to you.
post #5 of 12 Old 02-26-2010, 02:05 PM
JJorda
Jeep. Jeep? Jeep! Jeep.
JJorda's Avatar
Do you hear the motor run when the wipers are on, but not moving? Mine stopped working a while back, when I dropped the windshield I noticed the nut holding the linkage on fell off the motor. I put everything back together, all was good afterwards. I don't want you to spend the money on a new motor if it's not needed.
1989 Jeep Wrangler - Daily Driver and project - Red Jeep Club #216, NRA Jeep Club #5
1967 Chevelle SS396 - Main Project <--454, TH400, 4.10's, FAST
1982 Caprice Classic - Another project <-- 350/700R4, 4 wheel discs
1979 Honda Civic CVCC - Yet another project <--goal of 60 mpg
JJorda is offline
post #6 of 12 Old 02-26-2010, 02:29 PM Thread Starter
Lambo3244
No sound when I turn the wipers on. I kinda already thought about the linkage in stuff but there is no noise coming from the motor...
post #7 of 12 Old 02-26-2010, 02:31 PM
H3RTCH
Live Free or Die.
H3RTCH's Avatar
Well do they work when dry? If its a wet-only issue its probably a short in the wire like said above.
Brandon
2004 Jeep WJ Grand Cherokee Overland - My DD
1988 Jeep MJ Comanche 4.0L - Dad's
1999 Jeep WJ Grand Cherokee Limited 4.0L - Mom's
H3RTCH is offline
post #8 of 12 Old 02-26-2010, 02:44 PM Thread Starter
Lambo3244
Well I dont usually use them when it is dry out. haha. It has to be the short in the wire. I will check it out today.
post #9 of 12 Old 02-26-2010, 05:35 PM
Matt_vs_YJ
IIRC the wipers are on a circuit breaker rather than a fuse. If it trips then they won't work until it resets itself after cooling down. It looks like a fuse, but made of metal and possibly stamped with something like 6.3 amps.
I had the same problem you are describing and it turned out to be the contacts in the fuse panel were corroded and causing the breaker to trip.
Call me Matt. I have a YJ.
If you're in the Hampton Roads area of Virginia check out the Middle Peninsula Jeep Association
Matt_vs_YJ is offline
post #10 of 12 Old 02-28-2010, 05:17 PM Thread Starter
Lambo3244
Hey guys. I folded down the windshield and checked the wires and the ground wire's bolt was loose. (: Tightened er' up and made sure everything else looked good. Hopefully that fixed my issue. Thanks for the help.
Lambo
post #11 of 12 Old 04-08-2010, 07:38 AM
Jthomps6
So what was the end result this is happening to me. Wipers start working in the beginning but as I get about 5-10 min of drinving in the rain they slowly stop working and this does not happen when it has been dry for at least a few hours.
Also, having a problem with my lighting. My dash lights and parking lights aren't working. my front right turn signal isn't working either but the bulb is fine all other turn signals work. My headlights and brake lights work. Fuse?
Jthomps6 is offline
post #12 of 12 Old 04-08-2010, 03:19 PM Thread Starter
Lambo3244
My problem actually turned out to be the wire that runs from the wiper motor to where it plugs into another connector somewhere near the steering column under the dash. The wire had just enough of getting pinched when the windshield is folded up and bolted to the rollbar. I couldn't get just the wire so I had to replace the whole wiper motor.
As for the blinker issue, try replacing the flasher in the fuse panel under the dash (driver side). And for the dash and parking lights, try replacing the switch. It looks like this:
Jeep Wrangler Headlight Switch at 1AAuto.com.
Good luck!
windshield wipers stopped working!?! bigredtoy TJ Wrangler Technical Forum 10 11-29-2010 11:38 AM
windshield wipers not working 00tjtyler TJ Wrangler Technical Forum 5 02-25-2010 01:23 PM
Windshield Wipers working on Hi, but nothing else bdrayer TJ Wrangler Technical Forum 2 12-03-2009 02:21 PM
windshield wipers not working correctly? 08jk JK Wrangler Technical Forum 0 09-09-2008 10:21 PM
Windshield Wipers Stopped Working slate210 TJ Wrangler Technical Forum 7 05-05-2008 11:46 AM
