Windshield wipers not working - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Windshield wipers not working
New For October! Flowmaster Black Ceramic Coated 304S ExhaNew For October! Flowmaster Black Ceramic Coated 304S ExhaPremium LED Lighting by VISION X, Proudly sold at ROCKRIDG
Unread 10-13-2010, 06:15 AM   #1
05F1FIDDY
I have a 94 YJ and the windshield wipers stopped working. They came on for a sec then stopped. I'm new to Jeeps, I have no clue on how to fix it. I changed the fuse, but still not working. Thought it could be the switch, but the washer fluid still sprays. What could be the problem? Thanks for the help
05F1FIDDY is offline   Reply With Quote Quick reply to this message
Unread 10-13-2010, 07:52 AM   #2
whyjay
Mine did that once. Look under the dash near the stearing colum & there is a wire harnes that comes disconected just enough to lose contact. Thats what mine was. I hope this helps.
whyjay is offline   Reply With Quote Quick reply to this message
Unread 10-13-2010, 09:33 AM   #3
57plymouth
That, or if you have delay wipers the module could be broken. You can remove it and connect the two harnesses together until you can get a spare out of a junkyard.
Virtus Junxit Mors Non Separabit
57plymouth is offline   Reply With Quote Quick reply to this message
Unread 10-13-2010, 05:30 PM   #4
94yjsahara
I removed my module and connected the two harnesses together.
the good - the wipers worked.
the bad - my column started smoking after about 20 seconds where the switch is located.
anybody have any ideas?
hopefully, maybe the switch is just hooped - will a switch change fix the problem? or....
maybe the motor is old and becoming inefficient? drawing too many amps and melting my switch out?
does the intermittent module have some sort of resistor that limits the amount of electricity going up to the switch?
I dont want to hook up my new wiper swich in case it starts melting the new one
how should I go about this?
94yjsahara is offline   Reply With Quote Quick reply to this message
Unread 10-13-2010, 08:26 PM   #5
dancytron
You get to put the windshield down.
Once you do, the windshield wiper motor is right there out in the open on the driver's side. You can get an inline fuse, some wire, and a 2 position toggle switch and rewire the whole thing or start testing the wires going into the motor to fix it back to stock (which I wouldn't know anything about).
edit: you should try regrounding the motor once you take the windshield down.
dancytron is offline   Reply With Quote Quick reply to this message
Unread 10-13-2010, 09:24 PM   #6
94yjsahara
sounds good! I'll try regrounding it first, but does anybody have a writeup for overhauling the motor?
Unread 10-14-2010, 04:21 AM   #7
johnboy68
HIP2BSQR
johnboy68's Avatar
I've got a spare motor I can make you a good deal on.
Skip a kit like you skipped other things. Don't be a dork.
johnboy68 is offline   Reply With Quote Quick reply to this message
Unread 10-14-2010, 07:39 AM   #8
BigBass
Could you do me a favor and get a picture of the plugs both mine and my brothers YJ have no wipers and its a bummer.
All Long Islanders Check out OutLawedOffroad.com throw my user name BigBass in the referral box
BigBass is offline   Reply With Quote Quick reply to this message
Unread 10-14-2010, 05:46 PM   #9
94yjsahara
you're in west virginia? i'm in vancouver bc lol. I'm going to try to see if I have a loose ground first thats making my wires run hot.
bigbass - the plugs? are you talking about the harnesses on both sides of the wiper module?
if you are, really don't need a picture... just look under your dash just to the right of your e-brake release, there should be a metal plate there with a box VELCROED to it. that box is your intermittent wiper module.
unplug both sides of the module and then put the plugs together (without the module in the middle). thats it!
if your wipers work after you've done this (you wont have intermittent at this point) your motors and switches are fine, just replace the module.
just heads up though, when I did this the switch in my column started smoking! if your switch isnt' fried should be ok
Unread 05-20-2013, 06:54 PM   #10
Dlones
have this same problem, i tried connecting the wires together without the intermittent module and it didnt work. so i guess it the switch or the motor? could there be a bad ground causing this to happen?? if so where does the ground run to? and wheres the switch that could be bad???
Dlones is offline   Reply With Quote Quick reply to this message
Unread Today, 03:10 PM   #11
Red90Islander
I lost my wipers and found that the harness on the backside of module had become partially unplugged..thanks guys, 2 sec. fix!
Red90Islander is offline   Reply With Quote Quick reply to this message
