Windshield wipers not moving - JeepForum.com
post #1 of 6 Old 12-18-2006, 06:29 AM Thread Starter
RANGER_DANGER
On my recently purchased 94 YJ now that my electrical problem is fixed I found that the windsheild wipers simply hum and move back and forth fast but don't go across the windsheild. You can only tell they're moving if you touch the wiper otherwise it's just humming. Do you think it's the motor or could it be a linkage somewhere? Any help would be appreciated.
RANGER_DANGER is offline
post #2 of 6 Old 12-18-2006, 07:42 AM
crosschecker
1995 XJ Cherokee
If the motor is just humming, I would lean toward it being the motor. If it were the linkage, there would probably be some strange noises and movement from the linkage trying to move.
crosschecker is offline
post #3 of 6 Old 12-18-2006, 08:05 AM Thread Starter
RANGER_DANGER
Thanks, I'll take it apart and see if I can't replace the motor or if there is something obvious that is wrong. The weird thing is that the person i bought it from got the windshield frame repaced and he said after that the wipers screwed up and didn't wipe. Could the wires be pinched or something?
post #4 of 6 Old 12-18-2006, 08:10 AM
crosschecker
1995 XJ Cherokee
If the wires were pinched, there would be no hum from the motor.
post #5 of 6 Old 12-18-2006, 08:19 AM
tdewit
Sounds to me like one or both mechanical links are not connected. The humming is probably from the motor turning, but no links are connected. Loosen the windshield so you can tilt it forward, then you'll be able to see the links.
tdewit is offline
post #6 of 6 Old 12-18-2006, 08:24 AM Thread Starter
RANGER_DANGER
alright, i'll do that, hopefully by the end of the night my jeep will be in good working order! Not bad for a 1700 dollar jeep that only needed about 300 dollars worth of parts (so far)!
no windshield wipers lonestar_yj YJ Wrangler Technical Forum 13 03-16-2009 07:47 PM
Windshield wipers PhatXJ YJ Wrangler Technical Forum 22 06-01-2006 11:41 PM
Windshield Wipers (Need Help) Milla TJ Wrangler Technical Forum 5 03-15-2005 04:09 PM
windshield wipers cbert TJ Wrangler Technical Forum 3 05-27-2003 11:44 AM
windshield wipers funerald55 YJ Wrangler Technical Forum 3 01-04-2002 06:47 PM
