Windshield Wiper Problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Windshield Wiper Problem
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDSPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!
Unread 09-30-2014, 07:57 AM   #1
flcracker
I searched and couldn't find a problem like mine so here goes.... Wipers come on and work fine for a few minutes then gradually slow to nearly nothing. Am I looking at a ground problem or a wiper motor problem?? Something else??
Not the sharpest bulb in the box....
My Jeep is possessed with the goal of making me lose my religion....
flcracker is offline   Reply With Quote Quick reply to this message
Unread 09-30-2014, 08:52 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I use a booster cable from the battery negative to the motor case to verify grounds. The motor uses the hinges for a ground so adding a dedicated ground isn't a bad idea. On most, that even speeds them up.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 09-30-2014, 10:33 AM   #3
superj
1987 YJ Wrangler
do you have intermittent on yours, flcracker? if so, the little black box under the dash, above your left knee, could be giving you trouble also. its the control box for intermittent wipers and you can take it off and open it up and clean everything, or just take it out and connect the plugs that go into each end of it together to remove the intermittent feature
Slow ride, take it easy
superj is offline   Reply With Quote Quick reply to this message
Unread 09-30-2014, 10:34 AM   #4
flcracker
Pulled the box out a while ago with no change.... I do need to take that thing apart and clean it up inside though... nice to have
Unread 09-30-2014, 05:45 PM   #5
JMickey
The wiper delay box under the dash most likely has nothing to do with the problem you described. Either the ground is bad or the motor is going bad. As the motor is running heat and resistance increase on a motor that is failing, hence it slows down as it runs. Could also be lack of lubrication in the motor itself. However lubing it at this point is only delaying the inevitable if lubrication is the issue. Check the grounds.
JMickey is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 07:23 AM   #6
JeeperDon
Patience, Grasshopper
JeeperDon's Avatar
That may be for a CJ Mike, but the YJ harness has a ground wire on its plug under the dash.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" BFG KM2's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
Unread 10-01-2014, 08:45 AM   #7
Que89YJ
Your wiper motor is going bad. There is no point in playing around, it needs to be replaced.
Que89YJ is offline   Reply With Quote Quick reply to this message
