Windshield Wiper Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Windshield Wiper Help
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 01-13-2015, 10:03 PM   #1
M35A2
1995 XJ Cherokee
Did some research here, did some testing, just want a second opinion, or third, or fourth
While I was doing the Howell conversion, I tackled the windshield washer fluid into the cabin issue. Turns out that when the po painted the pig, they removed the windshield squirters and let the plumbing fall into the cowl area, what a biatch to fish out, gimmie an XJ any day!!
Well, after I sorted that issue out, I figured i'd try the wiper issue. They only work on the high setting and do not "park" I was initially thinking the switch was junk, but, if I un-plug the intermittent module, they don't work at all. When I have the module in series, you can feel it click when the position of the switch is changed. If you move the switch from off to int, the module clicks but no wipers. From int to low it clicks, but no wipers. From low to high it clicks and then the wipers move, but in the low speed.
I THINK it's the wiper motor or circuit to the motor from the module. Any pointers out there to help confirm my diagnosis?
BTW, How on earth does one change a wiper motor on one of these?
Oh yeah, since I can't figure out how to add a second vehicle in my profile, this is a 1989 YJ, 4.2, auto, A/C, hard top.
Thanks all!
Volunteer, American Society of Military History. http://tankland.com/
Just got a 1989 YJ too!
M35A2 is offline   Reply With Quote Quick reply to this message
Unread 01-13-2015, 10:24 PM   #2
Chrisnvegas
Chrisnvegas's Avatar
Im working on my wipers right now. I just ordered a control module. Plug the two plugs together
With the module removed. If it's the module, everything should work normal except the delay.
What happens in my Jeep, stays in my Jeep
Chrisnvegas is online now   Reply With Quote Quick reply to this message
Unread 01-13-2015, 10:29 PM   #3
Luuca
Professional Novice
Luuca's Avatar
Check Your Ground!!!
91 YJ "Alice" 2.5L AX5 D30/35 -Busted Knuckles Yellow Jeep Club #91
05 LJ Rubicon "Ghost" 4" RE Lift 1" BL 33s
94 XJ FOR SALE
Luuca is online now   Reply With Quote Quick reply to this message
Unread 01-13-2015, 11:32 PM   #4
M35A2
1995 XJ Cherokee
Sorry, thought i wrote that i did the module bypass, i just said i u plugged jt. I did plug the two harnesses together, still only has low speed in the high position. Where is the ground for the wipre circuit located? It is a birdsnest under the dash!
Unread 01-13-2015, 11:36 PM   #5
Luuca
Professional Novice
Luuca's Avatar
http://bit.ly/1Cigcy1
On my LJ, the wiper motor ground is spliced into the driver's side headlight ground on the grill shell. Ask me how I found out.
If you are in there at the motor, look at some of the diagrams and make a temporary ground wire to the black wire. If they work as intended, make it permanent.
94 XJ FOR SALE
Unread 01-14-2015, 08:14 AM   #6
JeeperDon
Patience, Grasshopper
JeeperDon's Avatar
They ... do not "park"
Parking is a function of a second +12v line to a switch inside the wiper motor assembly. When +12 is on that line, it continues to run the motor after the column switch is off until that internal switch goes off by the wipers getting to the park position.
Here is the wiring page PDF from the FSM.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" BFG KM2's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote Quick reply to this message
