Windshield Quick Drop - Page 2 - JeepForum.com
post #16 of 23 Old 09-30-2013, 09:35 AM
HaskiE
HaskiE's Avatar
Originally Posted by Rproject View Post
Most certainly, but the spreader bars are only attached with 1 bolt at the roll bar. Easy enough to remove.
x2, if you remove the padding from the main bar, you can remove the little post they mount to as well - also only one bolt each.
#theneverendingaxe
HaskiE is offline
post #17 of 23 Old 09-30-2013, 09:40 AM
ddferdt
Originally Posted by HaskiE
lol newb! that would be dangerous, definitely take the roll bar spreader bars off.
Wow I really am a newb. I had no idea the spreaders even came off. I feel dumb
ddferdt is offline
post #18 of 23 Old 09-30-2013, 09:52 AM
Rproject
1987 YJ Wrangler
X2 and removing the posts cuts down on the whistling when the windshield is down.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #19 of 23 Old 09-30-2013, 11:32 AM
HaskiE
HaskiE's Avatar
Originally Posted by CrawlingForward View Post
I've got the RockHard4x4 sports cage (good investment if you have the windshield down often and daily drive it)
I swapped the stock bolts for grade-8 head head and only leave one on each corner in.
A ratchet with a 1/2" socket and 4 bolts and it's down!
Nice!
Hey I know you!
You moved to Texas??
We've all been there!
#theneverendingaxe
HaskiE is offline
post #20 of 23 Old 09-30-2013, 07:27 PM Thread Starter
Colton123
Thanks for the ideas! I'll get the CJ knobs on order, but I'm still up in the air about the roll bar spreader bar. I was thinking about sectioning out a 6" piece near the windshield bracket and sleeve it with a larger (on the outside) 12" tube. Then using the same CJ knobs, drill and tap, and then I would have my quick disconnect for the spreaders. Anyone done this? I use those bars to attach my bimini top when driving around daily because it's easy to take off and put on.
Colton123 is offline
post #21 of 23 Old 09-30-2013, 07:32 PM
Rproject
1987 YJ Wrangler
I use a CJ style bikini top. No spreader bar needed for the original bikini top.
1996 White ZJ
Rproject is offline
post #22 of 23 Old 10-01-2013, 05:48 AM
HaskiE
HaskiE's Avatar
x2, I was gonna say the same thing!
#theneverendingaxe
HaskiE is offline
post #23 of 23 Old 10-01-2013, 07:56 AM
HaskiE
HaskiE's Avatar
bikini pics!
#theneverendingaxe
HaskiE is offline
