windshield bolts - JeepForum.com
post #1 of 8 Old 10-24-2013, 01:59 PM Thread Starter
Mattias25
windshield bolts
So im having trouble getting those top bolts off the hinge for my KC brackets, We have tried impact driver after i broke one of the bits inside it. Im considering heating it up, and last option going in with a smaller bit and then backing it out
Mattias25 is offline
post #2 of 8 Old 10-24-2013, 02:02 PM
baktie_91YJ
This is a common problem, you can try locating the nuts on the inside of the tub and using a wrench, may be hard though
baktie_91YJ is offline
post #3 of 8 Old 10-24-2013, 02:16 PM
CB10101
Mine had some goop on the nut inside the dash. I have read this to be true for most people changing these out. Scrape off the goop with a large screwdriver then put a (1/2"????) box end wrench on the nut. i had to ask my wife to hold the wrench while i used a torx bit on a ratchet for the bolt.
Edit...
Think the top bolts went into threaded inserts in the windshield, mine came out really easy
CB10101 is offline
post #4 of 8 Old 10-24-2013, 04:15 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Try an impact wrench turned down a tad. Should come right out. Replace with hex head bolts
Luck Favours The Prepared
Anticanman is offline
post #5 of 8 Old 10-24-2013, 07:16 PM Thread Starter
Mattias25
I thought only bottom had nuts
post #6 of 8 Old 10-24-2013, 07:19 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
I'd drill them out. Its not like you want to reuse those POS torx head bolts again.
Mine is a '91 too. It had nylock nuts with red loctite and was sprayed with sealer too. PITA.
Joe Dillard is offline
post #7 of 8 Old 10-25-2013, 06:18 AM
Old4X
1990 CJ7
A drill is the go-to tool for removing torx if they don't come out on the first try. less than 2 minutes and they are out.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #8 of 8 Old 10-25-2013, 09:09 AM
tom_sprecher
Which bolts exactly? If they are on the bottom half of the hinge you can drill them out. If on the top half they thread into a blind nut plate in the windshield frame. Drilling could mess up the threads in the nut plate.
Scraping the goo off makes getting the bolts out easy, but scraping the goo is a PITA.
Tom
tom_sprecher is offline
