Windsheild Frame Bolts - JeepForum.com
post #1 of 7 Old 11-04-2011, 09:03 AM Thread Starter
clush
Hey Guys,
I have my windsheild frame off, getting new glass plus I had to fix some rust issues. My problem is that on the drivers side front part of the windsheild - the part behind the sheet metal that the windsheild frame bolts thread into broke off and is rattling around inside there. I figured I will just have to somehow fish it up there and then get a bolt started........but I thought since this forum is such an excellent resource I would see if anyone has encountered this and/or see what workarounds folks might know about. I am going home tonight to herc the frame (rather than paint) and the glass guy will be putting glass in for me next week. Then I can finally start buttoning all this body work up.
Thanks
Clint
clush is offline
post #2 of 7 Old 11-04-2011, 11:55 AM
Que89YJ
Here is a bump for you. I haven't done mine yet, but I know there are many on the forum that have.
Que89YJ is offline
post #3 of 7 Old 11-04-2011, 11:59 AM
nembudonna
I don't know of any way or have I ever read on here a way. Good Luck.
nembudonna is offline
post #4 of 7 Old 11-04-2011, 12:03 PM
Alfons
You should be able to shake it out through the area where the wiper connection rods fit at the bottom of the frame. Put that piece back (using a large screw driver or one of those tools with a magnet on the end). When you see at least one of the threaded holes, put a bolt in place to hold it from falling back inside. Move it to get the other hole aligned and put a bolt loosely into place, then squeeze some RTV into the hole to go between the windshield frame and the threaded plate. Now pull the bolts snug and let the RTV set & when that's done, you're ready to re-assembly everything.
You'll probably need to remove the wiper connection rods and maybe even the shafts that go through the windshield. The rods pop off - the joint is a steel ball and plastic (I think it's nylon) cup and I use a trim removal tool to pop the cup off the ball. When reassembling, you'll need to take care not to bend things - I use a pair of channel-lock pliers to pull the two pieces together. If you need to remove the shafts, they each have a nut on the outside of the windshield. Once that's removed, the shaft & associated bushing will drop through - you might need to tap it out. I use some windshield caulking when I put these back into place to stop any leaks.
Alfons is offline
post #5 of 7 Old 11-05-2011, 02:56 PM Thread Starter
clush
Excellent idea on the silicone. I managed to fish it up there today and got the bolts started but I was trying to think of a way to keep it there when I ultimatley need to bolt it to the windsheild hinge in the body. It was tedious to get up there, took me like 1.5 hrs and lots of winsheild flips to finally get it to line up so I could put bolts in there.
clush is offline
post #6 of 7 Old 11-05-2011, 03:48 PM
bkn1971
Originally Posted by clush View Post
Excellent idea on the silicone. I managed to fish it up there today and got the bolts started but I was trying to think of a way to keep it there when I ultimately need to bolt it to the windshield hinge in the body. It was tedious to get up there, took me like 1.5 hrs and lots of windshield flips to finally get it to line up so I could put bolts in there.
I used long set screws to keep the plate somewhat in place but pieces of threaded rod would do the same thing. good luck.
bkn1971 is offline
post #7 of 7 Old 11-30-2011, 10:40 AM Thread Starter
clush
bkn, I used some threaded rod thanks to your suggestion and it worked great. Got it on last weekend, thanks for the idea!
clush is offline
How do I get the windsheild bolts out? white_elephant YJ Wrangler Technical Forum 10 07-08-2010 05:26 PM
Windsheild Frame Bolts gtospeeding TJ Wrangler Technical Forum 7 04-27-2009 06:41 PM
Windsheild frame 69junk Wrangler General Discussion 2 11-12-2008 08:11 AM
q tec windsheild frame? joe's_yj YJ Wrangler Technical Forum 1 05-06-2007 10:03 PM
Windsheild bolts help andrew.lymberis TJ Wrangler Technical Forum 2 12-28-2005 02:59 PM
