Wind Channel Question - JeepForum.com
post #1 of 4 Old 05-06-2002, 07:54 PM Thread Starter
Johnny'sJeepen
My 89 YJ has the hardtop. I just got a bikini top and my question is this. If I put the wind channel on will I run into problems with the channel being on, and then placing the hard top above the channel? Any advice would be helpful. Iím not to sure how this set up works.
Thanks
J
Johnny'sJeepen is offline
post #2 of 4 Old 05-06-2002, 09:03 PM
Jeepfreak81
Jeepfreak81's Avatar
your hard top WILL NOT fit with the channel... i tried even trimmed it -- i needed a new one either way the next spring, it will either not go on or will leak if you do get it on, i used self tapping bolts now-- about double the original amount that way it is removable, i used to have the old one pop-rivited but drilling them out every fall sucked, a frind of mine used drywall anchors and went all the way through the frame worked well, i also put a foam weather strip under mine rather then silicone, when i used slicone it got into the frame and it has since started to rust, i am not sure on the foam, but so far hasnt seemed to leak
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #3 of 4 Old 05-08-2002, 07:54 PM Thread Starter
Johnny'sJeepen
JeepFreak,
Thanks a bunch for the advice. I will look into the drywall anchors. Good idea!
J
post #4 of 4 Old 05-08-2002, 10:31 PM
Jeepfreak81
no problem man
Wind Noise Question RocksHurt JK Wrangler Technical Forum 1 01-23-2008 02:37 PM
Wind / hood question element981 JK Wrangler Technical Forum 22 01-01-2008 09:17 AM
Question about the Windshield channel from 4wd.com woodb TJ Wrangler Technical Forum 2 07-26-2006 10:02 PM
question about windshield channel losfreddy TJ Wrangler Technical Forum 1 04-04-2006 01:26 PM
Repair question (wind ripped up my top) ergh99 YJ Wrangler Technical Forum 10 01-23-2006 03:32 PM
