winch way is up? - JeepForum.com
post #1 of 13 Old 02-23-2008, 07:21 AM Thread Starter
hevybluzer
winch way is up?
I have been looking at an 8,000# rated winch that weighs in around 110#. If I was to mount this unit to the front of my '95 YJ, would there be a need for any type of suspension mods to keep the jeep "level" or would the 100+#'s be "unnoticed". Thanks. By the way, the suspension is stock.
hevybluzer is offline
post #2 of 13 Old 02-23-2008, 07:40 AM
bgredjeep
1987 YJ Wrangler
I guess you are talking the 8274. Sit on the nose of your Jeep and have someone take a profile pic. That should give an idea of what the winch plus mount etc. will do for you. It is likely that the front may sag a bit faster with the weight staying there for a long time but I don't personally have experience with that winch on my rig.
bgredjeep is offline
post #3 of 13 Old 02-23-2008, 08:29 AM
Dave R.
My guess is if this is still the stock suspension, it has already sagged some winch or no winch. My 95 has a winch on the front and sagging is very noticeable. At the very least you may want to consider beefier shocks. JMHO
Dave R. is offline
post #4 of 13 Old 02-23-2008, 09:56 AM
flysyj
flysyj's Avatar
my m8000, made the front of my jeep sag a bit..i have an re 4" and i am now trying to figure the best way to bring it back to level~
flysyj is offline
post #5 of 13 Old 02-23-2008, 02:04 PM
goatboy
Shocks are NOT designed to off set sagging shocks or additional weight UNLESS they are coil over shocks...they are designed to damp the springs...this is a very common misconception...you might consider a set of 'Load Leveler' shocks..that name is owned by Monroe, who made some of the first coil overs...might work for ya...
goatboy is offline
post #6 of 13 Old 02-23-2008, 02:28 PM
flysyj
flysyj's Avatar
i'm thinking 5/8 boom shackles...take a measurement, mount your winch and see what happens a month or so down the road..and make adjustments then..a good winch is still a life saver~
flysyj is offline
post #7 of 13 Old 02-23-2008, 04:15 PM
wildchild
I just bought a Mile Marker 8000# winch and it only weighs 82# according to UPS. I built a custon bumper that may weigh in at around 70# and with both on the front I did not notice any sag. But my springs are a little stiff. If it makes yours sag you can always add an additional leaf spring.
wildchild is offline
post #8 of 13 Old 02-23-2008, 04:54 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
t max 9500lb and a hefty bumper. no sag on 2.5" old man emu springs, sprung over.
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
post #9 of 13 Old 02-23-2008, 06:36 PM
jaw41272
jaw41272's Avatar
Coil over shocks , just what every jeep owner needs, an even rougher ride, I like the sound of the 5/8 shackle lift, or just throw some more weight in the rear
91 Sahara 4.0l Operation Welcome Home Parade Veh #69
PARADE JEEP MEMBER #1Auto posi-lok equipped, 4" susp. lift
K&N Drop in and loaded with battle scars
FOR SALE 2005 PT CRUISER CONVERTIBLE
2005 Suzuki DRZ400S For SALE
jaw41272 is offline
post #10 of 13 Old 02-23-2008, 06:55 PM
leftlanetruckin
XJ on 37's
hmmm, lemme guess you havent had too much (if any) experience with a well setup pair of coilovers?? i have, and let me tell you from experience, no leaf spring in the world can come close to the ride quality and adjustability of coilovers.
just thought i would set the record straight, back on topic...
martin
post #11 of 13 Old 02-23-2008, 07:11 PM
jaw41272
jaw41272's Avatar
You misunderstand the coil overs in question are not replacing the leaf springs, they are used in conjunction with them, making a rough ride rougher by tensioning the coils to help lift a saggy spring, trust me I had these on a car when I was younger and it was a rough ride
What you are talking about would be a pretty expensive upgrade on a jeep
jaw41272 is offline
post #12 of 13 Old 02-23-2008, 07:17 PM
leftlanetruckin
XJ on 37's
you mean this?
he was talking about load leveler's, not coil overs....
and coilovers in heeps are not too uncommon, if you can grab some decent coilovers for the right $$$, not too bad at all. both me and scott have looked into this ourselves.
crossed wires me thinks......
martin
post #13 of 13 Old 02-23-2008, 07:25 PM
Voodoo1
Mount it and have fun.
If it makes a big diiference to the look or ride of your jeep, then it's time for new leaf springs.
no worries, just wheeling.
Peace.
Voodoo1 is offline
R/C winch plate & 8500lb Super winch on factory bumper. fernjack JK Wrangler Technical Forum 17 11-23-2010 10:12 AM
I'm an idiot.. and ordered a winch.. (Winch plate for stock bumper) RVA_TJ06 TJ Wrangler Technical Forum 32 12-26-2009 08:35 AM
Pics of new MOPAR winch bumper, the one w/fog light cutouts & Hyd winch nycrd JK Wrangler Technical Forum 25 12-11-2009 05:33 AM
Which winch plate for TKH Fab bumper + Warn winch? Achped TJ Wrangler Technical Forum 4 10-21-2009 02:56 PM
warn 8274 winch / looking for winch rope jeremy91yj YJ Wrangler Technical Forum 5 06-14-2009 08:36 PM
