Winch Questions - JeepForum.com
post #1 of 8 Old 03-06-2002, 09:15 AM Thread Starter
Black Dragon
Winch Questions
I am looking at buying a winch for my 89 YJ but don't want to spend a lot, I am thinking maybe a used one, can any of you give me suggestions on what I want to look for. Thanks
Black Dragon is offline
post #2 of 8 Old 03-06-2002, 09:25 AM
RodeoRob
RodeoRob's Avatar
Warn! M-series if you want cheap. Xi-series for nice all around, average priced winch. And then HS9500i or 8274 if you want the best.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 8 Old 03-06-2002, 12:18 PM
89 YJ
I got the 8274 .... Best thing iv put on my jeep. Look 4 a used one cause the new are 1300.00 I got mine used from a guy who didnt know what he had for 200.00 Lucky find. If u do alot of winching u cant beat the 8274 with 150 feet of 3/8 and the fast pull. Its rated at 8000 but iv pulled more with straight cable. Always rember with a winch u need a 800 cold cranking amp battery and an alternator of atleast 140 amps to make it work properly. Good luck, and make sure u put in a on off switch or fuselink so u dont catch fire!
89 YJ Islander, AC,PS, 10 inch lift, 32 BFG MT's, sway quick disconnect, rear track bar quick disconnect, 400 watt 12 speaker cd player for tunes,8000lb warn 8274 with 150 ft cable, and a high lift jack.. Lockers, 35's, webber carb and jacobs ignition comming soon.
89 YJ is offline
post #4 of 8 Old 03-06-2002, 10:51 PM
osburn
osburn's Avatar
-Rob
Man, that's the best quick recommendation I've ever seen. Ya nailed this one Rob. Surprised to see it come from a power steering winch owner.
Matt Osburn
Score 1032
osburn is offline
post #5 of 8 Old 03-06-2002, 11:00 PM
RodeoRob
RodeoRob's Avatar
And an Isuzu owner to boot!! Go figure!
-Rob
Robert Gorrell
RodeoRob is offline
post #6 of 8 Old 03-06-2002, 11:49 PM
Josh
He must know about winches and getting stuck since he owns a Rodeo
1987 Wrangler, mods...currently torn apart, working on new motor, SOA, Dana 300, d44 front, ford 9 rear
Josh is offline
post #7 of 8 Old 03-07-2002, 12:05 AM
RodeoRob
RodeoRob's Avatar
Or maybe that knowledge comes from all the stuck Jeeps I've pulled out? Guess you won't know til you see me out on the trail hehe
geez osburn, i see your attitude is rubbing off on your fellow jeepers... pretty soon everyone will be taking cheap shots at the "ricer dude"
-Rob
Robert Gorrell
RodeoRob is offline
post #8 of 8 Old 03-07-2002, 02:52 PM
I-4
I-4's Avatar
i recently picked up a used 8274 that needed a motor for $350.new motor(not from warn) $200.and a winch plate that i can easily adapt for my yj.btw rob,it's a jeep board,what do you expect?
95 yj...
who ever said putting a spool in a daily driver was a bad idea was just jealous he had not tried it first...
I-4 is offline
Winch questions Godholio YJ Wrangler Technical Forum 17 05-18-2008 10:39 AM
Winch Questions triplep JK Wrangler Technical Forum 17 01-09-2008 06:20 PM
Winch questions ski313 JK Wrangler Technical Forum 20 10-02-2007 08:51 PM
Winch Questions juiceparn JK Wrangler Technical Forum 8 06-11-2007 06:06 PM
Winch Questions holyearth TJ Wrangler Technical Forum 5 05-30-2007 10:41 PM
