01-10-2009, 03:18 PM
#1
Winch plate with feet (risers)
I'm getting no responses in the "General Offroading" section, so I figure I'll post here since you guys are much quicker with help/responses.
I picked up a "universal" winch plate off one of my neighbors (yay, I don't have to make one) and am in the process of modifying it to fit what I need.
What I want to do is add risers to it, right under the bolt holes to where it attaches to the frame. I plan on lifting the plate about 3/8" up using a couple of rectangles that are about 2" wide by 7" long, with holes cut in them for the bolts to pass through. Then i'll weld these beneath the plate.
Does anyone see a "problem" with this as far as structural stability/integrity is concerned?
Originally Posted by Mean Max
I think I'll keep the YJ. But can I talk you into taking the wife?
DISCLAIMER: I (usually) browse the web using Elinks in a (text only) terminal. Which means I do not have image viewing support. So if you get confused by my seemingly inability to comment on your pictures, emoticons, etc; now you know why.
If you're still confused click here to see how I view the forum.
01-10-2009, 03:23 PM
#2
I got some with my warn bumper, they work fine
01-10-2009, 03:27 PM
#3
Thanks, that's all I needed to know man.
I couldn't pass p a free winch plate. Modifying this one will be much better than cutting my own.
If it were't for the foot of snow we just got I'd have it installed already.
01-10-2009, 03:29 PM
#4
Enjoying the Ride
Sounds like a reverse TC drop for your winch.....
My Smittybilt plate came with two 1/4" spacers ( like a fat washer ) for use under the two rear mounting plate bolts. They levelled the plate ( front of the plate sits on top of the OEM bumper ). Smittybilt is okay with this arrangement so I am too. As long as you have solid metal between the bottom of the winch and the frame I would think it would hold up just fine.
My setup has been fine with half a dozen pulls, no shifting or movement.
01-10-2009, 03:36 PM
#5
I have a CJ with a custom built (strange, built by PO) round tube front bumper. I also had a custom built winch plate that I used to use on my Isuzu truck, it was a 3/8" plate with 2 2" square tubes welded to the bottom on opposite ends of the plate. I did this so it would be removable on that truck. Anyway, I bought the Jeep and dragged the winch plate out of the back of the garage (I sold the Isuzu a while back, and bough a F-150, which came with a Warn winch bumper installed by PO,) and lo and behold the 2" square tubes were perfectly spaced to fit my CJ frame, and lifted the winch high enough to clear my bumper. I haven't had any problems winching anything with the Jeep (I usually pull dead cars onto trailers more than anything else.)
01-10-2009, 03:51 PM
#6
Excellant!
Thanks for the reassurance guys.
01-10-2009, 03:56 PM
#7
Got my eye on you.....
Your definatly all set B. I would only see an issue if you were using some sort of funky bushing or something. With a FULL spacer you should have no issue.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
01-10-2009, 03:59 PM
#8
That was my line of thinking as well, I just wanted (needed??) reassurance.
I figured it the spacers I weld to the bottom of the plate were the exact same size as the frame, then it is still making the same ammount of contact.
Now I'm eager to see how much my front end sags when I get this thing all set up.
01-10-2009, 08:55 PM
#9
I mounted my winch plate ontop of the stock tow hooks, fits great.
BLACK JEEP CLUB MEMBER
1987 JEEP YJ LAREDO
4.2L,MC2100,TFI,NUTTERED
NP231,AX15,D30,D35
9,500LB WINCH,60"HI-LIFT
01-10-2009, 09:11 PM
#10
Either you are serious, and I am way off base with my thinking.
Or this was the best sarsactic post I have ever read, in which case I give you a big
Are you seriously saying that your plate is sitting 3/4" off the frame?
Got pics??
01-10-2009, 09:13 PM
#11
On a different not.
The holes in the plate I was given will not line up properly to my frame. So I'm going to tig weld some slugs into those holes and laser cut some new holes in there.
Can anyone tell me how far apart the two holes are? I know there has been a few pics posted with the information that is easily findable... but as alot of you know I don't have image capibilities on the terminal I use from work.
01-10-2009, 10:13 PM
#12
FORMELY BIGPIMPIN
  you say your making your spacers as wide as the frame? won't they hit the metal thats welded by the factory near the back of the bumper.
i didnt look at your jeep but , on mine im adding 2 holes 2 -3/4" back from the existing holes. the front set of holes are occupied by my stock bumper,and thats why i added two more. the holes on mine are 31 -1/4 " apart. (THE PICTURE MEASURMENT IS WRONG}
i wouldnt worry to much about how big the spacer is . remember that the winch is only held on by 3/8 bolts. you really dont need to have welded full length spacers, but if it gives you piece of mind go for it. how are you mountin the back of the plate since there are no holes?
red 92 yj,4.0,dana 44 rear,xj driveshaft,rubi 4-1 tc,35"tires,smitty built winch,oba, 6" flares,hand throttle,aussie's front and back,posi-lock,6" lift.anti-wrap, hombrew bumpers, rack and sliders,cb,rear shock truss <>< ,MY BUILD: http://www.jeepforum.com/forum/showt...hp?t=613943see
Two fish swim into a concrete wall. One turns to the other and says 'Dam!'
01-10-2009, 10:52 PM
#13
Electric Chair Operator
I don't foresee any problems at all by lifting it ~3/8".
My winch plate sits up ~1/4" above the framerails due to the mounting tabs of my homebrew bumper. I used some big washers for the rear as spacers to level things out. It's been this way for several years with no problems.
Incase you're wondering - that 1/4" plate that's just behind the winch mount that has a couple bolts running thru it is for my homebrew steering box brace & has nothing to do with the winch mount.
01-10-2009, 11:00 PM
#14
when i looked up a warn winch plate for my jeep the one i got has two legs and a plate. it's raised up i guess about an 3/4" or so and it did come with flat washers to use as spacers.i was a little weary of this but i figured it should be ok.i plan on having the legs welded to the top plate as extra security.
90 wrangler,4.2l,1" MML,CRT HEI Dist.,34/34(interco) weber, hurst shftr,5spd,5" BDS lft,f-d30/r-8.8,5/8 lft booms,1" bl,tflex belly up,JB convs. SYE,gdyr mtr35s,hurc'ed,smit src frt bump,gen-r rear bump w/tire carrier,f&r tube fenders,psc knokrs,r gen-rgt ful conr gurds,duel bat.,BIC,m8000
01-10-2009, 11:07 PM
#15
I've already taken care of all that previously. You know me, I have a welder, grinder, laser, etc... I just can't leave **** alone.
It's hard to explain, but my bumper mount will be integrated into the winch plate. Actually, I guess it will be easy to explain. I'm building my winch plate into my front bumper but plan on having it sit a bit higher. Once again, I point to the fact I can't leave **** alone!
Peace of mind is what I was hoping for when starting this thread, and have achieved it.
As for your last question there, it was answered just above this paragraph.
Thanks
