Winch or not - JeepForum.com
post #1 of 4 Old 06-26-2002, 10:23 PM Thread Starter
KYgreenYJ
Winch or not
My friend winched me out of a mudhole that was about the as wide as my jeep blocked at one end by a cliff and a monsterous tree at the other end. we spent a good 45 minutes going back and fourth in this hole trying to get out of one of the sides but i just couldn't get the traction cause im not locked. Now im thinking about a winch cause i could probably get one pretty cheap 400-500. Should I? Is it cheating? I would get locked but i don't want to spend quite that much money and risk killing my stock axles. im pretty new to wheeling and i just don;t want to have to go get someonewith another more capable jeep evertime i go to my friends farm and slide around in the woods. Alo what size would i need will an 8k lb be enough to pull me aroudn or maybe a friends cherokee or (gag) Explorer?
Black 2012 JKUR 2.5" Rock Krawler Max Travel suspension with Bilstein 5100's, 35X12.5R15 MTRK's on MB Ultras, Sleeved and gusseted front axle with Synergy balljoints, JCR bumpers F/R
Old Jeep, SOLD:
94 Green YJ SE 4.0L 5spd
3.5" BDS lift, 1"MML/BL, Revolvers, SYE/CV, no track bars or sway bars, MORE sport cage
Green Jeep Club Member #20
KYgreenYJ is offline
post #2 of 4 Old 06-26-2002, 10:36 PM
Dan's YJ
Yes, an 8000lb winch is enough.
Look at it like this, your jeep is pretty capable now, right. And your getting stuck every now and then. Well if you were locked, you might not get stuck as often but when you do, your really stuck. And it's gonna be that much harder to get you free.
I'd go with the winch unless you have a friend that has one. Just my $.02
1994 Bronco HD
Warn 8000
2"lift, 32x12.50
Locked
Dan's YJ is offline
post #3 of 4 Old 06-26-2002, 11:36 PM
Quan
Quan's Avatar
Get a winch.. I'm locked and I still use my winch. I don't think there is anything more valuable when you're stuck alone or with friends. I have a ramsey 8,000 lb and it does excellent for me. Get it, you'll be really glad some time... actualy, many times if you're like me
There comes a time... In every mans life, when decisions... have... to be made. Whether to toil, to labor, or just plain piss your days away.
Green Jeep Club Member #15
My Jeep Made Me Broke Club Member #2
93 YJ I-6 w/ stuff
Keep the greasy side down
Quan is offline
post #4 of 4 Old 06-27-2002, 12:21 AM
jonabbott23
i have teh warn hs9500i and lockright lockers...and i still use my winch too. i would go with the winch first....just cuz' you can get out wehn you get stuck instead of just getting stuck.
92' yj..RUST RED...6" PRO-COMP COIL CONVERSION..LOCK RIGHT LOCKERS F&R..WARN HS9500I...33"SUPER SWAMPERS...TAILGATE RACK...SOUND BAR AND SYE...UH MORE TO SAY BUT NOT ENOUGH ROOM
jonabbott23 is offline
R/C winch plate & 8500lb Super winch on factory bumper. fernjack JK Wrangler Technical Forum 17 11-23-2010 10:12 AM
I'm an idiot.. and ordered a winch.. (Winch plate for stock bumper) RVA_TJ06 TJ Wrangler Technical Forum 32 12-26-2009 08:35 AM
Pics of new MOPAR winch bumper, the one w/fog light cutouts & Hyd winch nycrd JK Wrangler Technical Forum 25 12-11-2009 05:33 AM
Which winch plate for TKH Fab bumper + Warn winch? Achped TJ Wrangler Technical Forum 4 10-21-2009 02:56 PM
warn 8274 winch / looking for winch rope jeremy91yj YJ Wrangler Technical Forum 5 06-14-2009 08:36 PM
