winch issue - JeepForum.com
post #1 of 3 Old 12-17-2008, 12:33 PM Thread Starter
plyguitar45
winch issue
ok, i was installing my superwinch a few days ago and accidently unscrewed a bolt which let [what i guess was some sort of] oil spill out. I didnt even realize it until it was all over the bumper.
it's the bolt circled in red:
so do i need to refill this with something?
if so, what?
i already posted this in off-road equipment but no response.
so thanks for any help
- New Jeep :D-
3.7L '04 Manual Liberty KJ, all stock
-SOLD MY JEEP :(-
2.5L Red '91 YJ w/
, 2" BL, 31" MT Baja Claws, Superwinch LP8500, RH4x4 Front Bumper, JKS Quick Disco's, Rampage Nerf Bars
plyguitar45 is offline
post #2 of 3 Old 12-17-2008, 01:34 PM
JFranko
I'd contact superwinch if I were you. IIRC correctly I used gear lube in mine when I removed the planetary gears, but I could be wrong, so I would contact superwinch before you do anything just to make sure
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline
post #3 of 3 Old 12-17-2008, 03:22 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
Call superwinch. prolly 2 cycle oil.
Bring it over, I have some.
Nice winch BTW. Make sure your work the cable out before you need to pull out Patrick.
hi Tyler.
- Ernie
Richmond88yj is offline
transmission issue ? drive shaft issue ? clutch issue..where to begin ?..... rthompson48082 YJ Wrangler Technical Forum 7 09-28-2009 05:07 PM
Power steering pump issue and Alternator wiring issue... Help.... rustywrangler YJ Wrangler Technical Forum 22 01-05-2007 02:16 PM
winch grounding issue/question UCTJ TJ Wrangler Technical Forum 1 01-11-2006 11:23 PM
New winch and ride height issue ? SoonerYJ TJ Wrangler Technical Forum 8 08-22-2005 07:35 AM
pcm dissconected, winch issue mudcover97 TJ Wrangler Technical Forum 6 05-17-2004 09:24 AM
