Winch battery ground wire getting hot! - Page 2 - JeepForum.com
post #16 of 24 Old 06-22-2013, 06:32 PM Thread Starter
AZdEvilYJ
Originally Posted by Siva283
Part of your prob is that corroded terminal. I have mine hook ed up the same way. With no issues there. Mine will heat up at the terminals on the winch motor only if I run it to long without a break. But yoy really need to clean that bat terminal up
Sent from my SPH-L300 using JeepForum
Ill give that a try tonight and see how it goes. Thanks man
'95 YJ 2.5L
March '15 YJ of the Month!
Exiled Offroad - Arizona
My Build Thread
AZdEvilYJ is offline
post #17 of 24 Old 06-22-2013, 06:34 PM
sjones26573
Well there we go then haha! The positive is like 00 battery cable or whatever. A pretty massive difference between the two...add that to the list of little annoying crap to fix.
Cheers
Are you sure you aren't confusing the ground for the solenoid box? My Warn uses the same gauge cable for the motor ground, but uses a 10ga ground for the solenoid box.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #18 of 24 Old 06-22-2013, 06:36 PM
Siva283
On engos the selinoid box ground piggybacks off the winch motor ground so there is only one ground that goes to the battery
Ask me how I know...
Siva283 is offline
post #19 of 24 Old 06-22-2013, 07:24 PM
TSEJEEPERS
I would get rid of that terminal all together and go with something like this.
http://www.farmandfleet.com/products...terminals.html
Get some new ends like this for your current wires.
http://www.farmandfleet.com/products...able-lugs.html
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #20 of 24 Old 06-23-2013, 03:15 AM Thread Starter
AZdEvilYJ
My engo has two grounds. The motor which leads to the battery and another for the solenoid which is a small 18ga that I hooked up under the grill. The motor ground is giving my Fitz. I cleaned up that terminal and got a nice new HD terminal for the positive and all seems good so far. We will see when I respool the cable with some load
'95 YJ 2.5L
My Build Thread
post #21 of 24 Old 06-23-2013, 11:39 AM
DirtKar
Maximum Effort
DirtKar's Avatar
Boy, that's all very familiar.
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #22 of 24 Old 06-27-2013, 12:10 PM
rambo3489
Here's how I have it hooked to the battery so I'm sure this is where the problem lies, but how else would I hook it other than this?
So there's a total of 4 cables hooked up there. The two main ground and motor ground, the the alternator upgraded cable and the winch.
You main issue may be with your battery. The corroded terminal is causing you to have a bad connection. (causing arching and excess heat) If you have the same corrosion problems I had replace the battery and you will be good to go. My terminal was corroding like mad. Cleaned it, put a new wire in, ect. Nothing helped. Put a new battery in and has been fine for over a year. Must have been dissipating acid fumes. Worth a thought.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #23 of 24 Old 06-27-2013, 12:38 PM
87TPIYJ
87TPIYJ's Avatar
1987 YJ Wrangler
I have a warn, but all my wires are 2ga except + wire(I bought 2a from napa and it says 2ga but it is really 1/0ga). I did relocate my soliniod box under the hood and myy longest run is the + wire @ 84" no issues. As far as the wing nut terminals they are the isht! Mine I had the same corosion and over crowded terminals like you until I swiched. good luck!
YJ 350TPI NV4500 HPD60 14BFF ARB Chromo's
March 2017 YJOTM
87TPIYJ is offline
post #24 of 24 Old 07-02-2013, 05:44 AM
vadslram
Thanks for all the replies guys!
Ya I did have an alternator problem which i have seemed to solved i hope, after everything I tried/fixed/ replaced it was a faulty breaker... Swapped it out and not an issue since.
As for the winch, there is a small ground that mounts to the body right under the grill (which had some chaffing on it that I fixed), and there is a large cable that runs from the winch to the (-) battery terminal. That is the one getting very hot.
I just got off work so ill post my pics when I get home
If the body and frame aren't grounded to the engine all your ground to the grill will do is keep the winch from falling off if the bolts fail.
Besides the ground I ran from winch to battery I have grounding straps from bat to body and frame and from engine to frame. The straps are all braided tin coated copper! 3/4 inch wide.(a little overkill) With that setup I don't have to ground the KCs or radios other than right at the mount.
Proper frame grounding should mean you don't have to run any ground from the winch, it should be a positive equivelant of 2/0 copper with just the bolts that hold it to the frame.
vadslram is offline
