willys cj2a on yj frame - Page 2 - JeepForum.com
post #16 of 24 Old 02-12-2008, 05:31 PM Thread Starter
Kalesinajeep
i cnat see any of your pictures
Kale Saether
1995 YJ Wrangler,1999 TJ 2.5L Motor
Rubicon Express Exteme Duty Lift,
Black Cragars,32" BFG MTs,
White Jeep Club Member #116
Kalesinajeep is offline
post #17 of 24 Old 02-12-2008, 05:55 PM
Jeepfreak81
Jeepfreak81's Avatar
I know I got the email from photobucket today never used that much bandwidth before
94 V8 YJ, SOA, H1's, 37's, HP D44, D60, 4.88's, winch and some other goodies
1946 CJ2A, 225 V6, T98 D18, Warn OD, D30/D44. Dual winches mild lift & 34's
1966 M416 1/4 ton Military Trailer Expo Trailer
Full Page Club member #004
Green Jeep Club Member #005
Jeepfreak81 is offline
post #18 of 24 Old 02-12-2008, 05:58 PM Thread Starter
Kalesinajeep
do you know any sites where i can seeplans or just see custom frames for a cj2a or a tube frame
Kale Saether
post #19 of 24 Old 02-12-2008, 06:04 PM
Jeepfreak81
Nope everything would be custom to do it, everyone does it different. Pirate would be the place to search around though.
post #20 of 24 Old 02-12-2008, 06:09 PM Thread Starter
Kalesinajeep
what do you mean by pirate like pirate 4x4 the forum
Kale Saether
post #21 of 24 Old 02-12-2008, 06:11 PM
Jeepfreak81
Yes...
post #22 of 24 Old 09-15-2008, 02:33 PM
Andy4802
The ONLY reason you cannot put YJ axles under a CJ is the drop of the front axle. If you want to put YJ engine, transmission and t-case it you can do it. Or any engine/tranny/tcase combo that will give you a drivers drop. IIRC 83 and up Cj's use wide track axles. I believe these are very close if not the same width as a YJ.
Early CJ's use Narrow track with a passenger drop front axle, these are IIRC ~1972 to 1982, before that they were even narrower. You CAN put them under a CJ of course they will stick out a bit, but it gives you more stability... It would be no different then puttin g FULL WIDTH axles under a YJ.
Wide track axles into an early CJ used to be a common swap for those that did not want to run Waggy axles (wider yet but they ARE ran in CJ's) You have to outboard the springs on the frame to do it. What you fail to realize is how truly narrow they original NT CJ axles are, and honestly they are not the best for wheeling on off camber terrain. I have layed my CJ2A on its side going around corners with a steep banking a couple times, I will happily take some wider axles under it and it CAN BE DONE.
IIRC this flatty has Waggy axles under it that are wider then YJ axles... Doesn't look badly out of proportion to me, and would be a pretty stable wheeler. It is all about what you want out of the rig.
Besides, if you don't want it wide you can run some large offset rims. I am running H1 rims on my YJ with 7" of backspacing to bring the width back in that I thought was too wide.
I know this is a late reply, but i just came across this thread while searching for something else. I have seen that green flattie in person and those are definitely not waggy axles. The entire drivetrain in that rig is from a Toyota.
Andy4802 is offline
post #23 of 24 Old 08-11-2011, 10:36 PM
JLITTY
1946 CJ2A
o snap
JLITTY is offline
post #24 of 24 Old 08-12-2011, 03:04 PM
wendell
1987 YJ Wrangler
I believe it would work better with a 4 cylinder yj as the cj-2a's nose is too short for an I-6. To strech the nose would ruin the original look. When people do engine swaps in the flat fenders they use a pinto 2.3, V-6 or V-8 because of the short nose. Since the orignal flat head 4 only had 60 hp, even the jeep 2.5 would have twice the hp and with 5:13 gears that the willys had would make an awesome off roader.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
bestop frame better than stock soft top frame? goose142004 YJ Wrangler Technical Forum 10 11-24-2009 12:34 PM
rigid frame or flexible frame blackcat471 TJ Wrangler Technical Forum 8 08-12-2009 02:18 AM
swap wrangler frame with cj7 frame midgetdog YJ Wrangler Technical Forum 7 04-15-2009 10:58 AM
Any YJ's running an older front clip?? MB, Cj2a, cj trevor98tj YJ Wrangler Technical Forum 2 11-07-2006 01:24 PM
53 willys tub on 88 yj frame swap? lastws6 YJ Wrangler Technical Forum 3 03-20-2006 11:00 AM
