Will this work to cut down for my sye driveshaft? - JeepForum.com
post #1 of 10 Old 01-18-2013, 08:14 AM Thread Starter
skiandgolf
It's listed as a 2004 Grand Cherokee shaft. Will it work to have cut down for my sye shaft? If so, what else will I need to make it work? Not going to put it in with my d35, but want to have it for my 8.8 upgrade.
1995 black hardtop 2.5, 5 speed. Bought in '08 with 49,000 original miles. 3.5 BDS, 1/2 in BZERK booms, 33 Mastercraft MT's, Warn 8274. Modding slowly.
1997 green softtop 2.5, 5 speed. Bought in '08 with 51,000 original miles. Wife's rig.
1995 green softtop 2.5, 5 speed. Bought in '08 with 101,000 miles. Son's rig.
skiandgolf is offline
post #2 of 10 Old 01-18-2013, 08:23 AM
SeanB95YJ
should work just fine
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #3 of 10 Old 01-18-2013, 08:49 AM
jokerchief462
Nice find will be just fine
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 10 Old 01-18-2013, 08:56 AM
PA_YJ19
Yes it'll work but ur gona Piss sum WJ owners off if they see it. The ujoint style shafts r hard to come by off the wj's, I have a friend that's been looking for one for like half a year haha. He'd prob kill for that shaft so he can use his 4wd again, they come with a shaft that doesn't have ujoints for the most part n wj owners who r lifted all go around looking for them. U may b able to sell it n make sum coin but I don't no what u paid for it in the first place.
PA_YJ19 is offline
post #5 of 10 Old 01-18-2013, 09:54 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Given that the ujoints are the same size and it mates to your SYE, it'll be just fine.
Luck Favours The Prepared
Anticanman is offline
post #6 of 10 Old 01-18-2013, 04:36 PM
CRASHNDENT
If you don't mind, what's the length on that from front U-joint to the back U-joint?
CRASHNDENT is offline
post #7 of 10 Old 01-18-2013, 04:54 PM
04WJny
1987 YJ Wrangler
Any clue on the wall thickness of the driveshaft tube? I think the ones from manual tranny XJs are .120 wall
Maybe ill steal the one off my WJ for my YJ build
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #8 of 10 Old 01-18-2013, 05:02 PM
skyj
The grand Cherokees are some odd ball size od smaller than xj. I had one I was going to use for my front shaft and the shop told me it was odd sized and would have to special order it and it was going to be $$$$$ so I went and pulled another XJ shaft from the jy. Not all WJ have that kind of shaft.
build thread:
skyj is online now
post #9 of 10 Old 01-23-2013, 01:56 PM Thread Starter
skiandgolf
So is anyone actually running one of these? Did you run into problems trying to get it shortened?
Thanks in advance for any help.
post #10 of 10 Old 01-23-2013, 05:57 PM
skyj
I run a XJ shaft which is basically the same thing just bigger diameter tube. No problem getting it shortened as long as you have a competent guy balancing it you should have no problems
build thread:
skyj is online now
