-   -   Will this work to cut down for my sye driveshaft? (http://www.jeepforum.com/forum/f12/will-work-cut-down-my-sye-driveshaft-1465386/)
skiandgolf 01-18-2013 08:14 AM
1 Attachment(s)
It's listed as a 2004 Grand Cherokee shaft. Will it work to have cut down for my sye shaft? If so, what else will I need to make it work? Not going to put it in with my d35, but want to have it for my 8.8 upgrade.
SeanB95YJ 01-18-2013 08:23 AM
should work just fine
jokerchief462 01-18-2013 08:49 AM
Nice find will be just fine
PA_YJ19 01-18-2013 08:56 AM
Yes it'll work but ur gona Piss sum WJ owners off if they see it. The ujoint style shafts r hard to come by off the wj's, I have a friend that's been looking for one for like half a year haha. He'd prob kill for that shaft so he can use his 4wd again, they come with a shaft that doesn't have ujoints for the most part n wj owners who r lifted all go around looking for them. U may b able to sell it n make sum coin but I don't no what u paid for it in the first place.
Anticanman 01-18-2013 09:54 AM
Given that the ujoints are the same size and it mates to your SYE, it'll be just fine.
CRASHNDENT 01-18-2013 04:36 PM
If you don't mind, what's the length on that from front U-joint to the back U-joint?
04WJny 01-18-2013 04:54 PM
Any clue on the wall thickness of the driveshaft tube? I think the ones from manual tranny XJs are .120 wall
Maybe ill steal the one off my WJ for my YJ build :D
skyj 01-18-2013 05:02 PM
The grand Cherokees are some odd ball size od smaller than xj. I had one I was going to use for my front shaft and the shop told me it was odd sized and would have to special order it and it was going to be $$$$$ so I went and pulled another XJ shaft from the jy. Not all WJ have that kind of shaft.
skiandgolf 01-23-2013 01:56 PM
So is anyone actually running one of these? Did you run into problems trying to get it shortened?
Thanks in advance for any help.
skyj 01-23-2013 05:57 PM
I run a XJ shaft which is basically the same thing just bigger diameter tube. No problem getting it shortened as long as you have a competent guy balancing it you should have no problems
The time now is 10:50 AM.
