Will a Weber fix this? - JeepForum.com
post #1 of 3 Old 02-28-2002, 08:09 AM Thread Starter
battlestar
I have a 1990 YJ with a 258-6. I've added an MSD ignition and done the Nutter Bypass. It is running pretty good now but... It takes three tries to get it started. The high speed idle(warm-up) doesn't work. It wont idle until it reaches operating temp. approx 200 degrees. I would like to be able to start the thing on one try and then let it warm up itself without me sitting there pumping the gas for 10 minutes. Does anybody know if a weber carb will correct these problems? Maybe you have some other suggestions. Thanks.
My Ride: 1990 YJ, 4.2, 5 speed, msd ignition, TFI Cap, 4" skyjacker lift, 1/2" shackles, nutter bypass, bestop seats, herculined floor, Flowmaster, Oversized cat, Xterrains on Rock Crawlers
battlestar is offline
post #2 of 3 Old 02-28-2002, 08:35 AM
Roachen
I have an 88 yj that had the same problem. A weber was well worth the investment.
Roachen is offline
post #3 of 3 Old 02-28-2002, 09:55 PM
oilfieldtrash
You may try adjusting your choke; if that doesn't work, it may need to be replaced. That's a buttload cheaper than a new carb, but it doesn't fix all the problems that go with this carb. My bucks will be going to a F.I. setup just as soon as I need to rebuild
"What, behind the bunny?"
'87 Wrangler- 3-1/2" suspension, 1-1/2"body w/ 33's, HEI and the Nutter bypass
'83 Blazer- 8"suspension, 3" body, 35-15's and soon to get the 383!
oilfieldtrash is offline
some weber questions for weber users giggityjeeper YJ Wrangler Technical Forum 12 06-09-2010 09:24 PM
Weber 34 DGEC Versus the Weber 32/36 DGEV FrankieCarbone YJ Wrangler Technical Forum 24 03-06-2010 09:33 AM
To Weber or Not To Weber, THAT is the question. Delta347 YJ Wrangler Technical Forum 4 01-17-2009 06:29 PM
weber oldwindsurfer YJ Wrangler Technical Forum 1 02-27-2008 06:56 AM
weber? toates89 YJ Wrangler Technical Forum 2 03-07-2006 05:13 AM
