Will TJ flares fix this? - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Will TJ flares fix this?
All Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 08-11-2011, 06:41 PM   #16
Anticanman
The Thunder Chunky
Anticanman's Avatar
Got them drilled and installed with (temporary) 1/4" bolts. I'll probably just pull the liners or use the material somehow to keep the noise down. Anyone ever cut it up and glued it to the steel?
Project for next week: cut flares and body to match.
Thanks for the help, Gents.
Luck Favours The Prepared
Originally Posted by rambo3489 View Post
Listen to what the canman says. You don't have to take it all word for word. But at least listen to the man. He knows his ****. Its a no BS straight to the point realistic approach to things. You may not like it. But someday you might have an Anticanman moment. Like you just had. I know I have. Hell I had 2 last week.
Anticanman is offline   Reply With Quote Quick reply to this message
