Will these tires fit???? - JeepForum.com
post #1 of 6 Old 02-16-2002, 08:29 AM Thread Starter
Mike611
Mike611's Avatar
Hey guys, i was wondering if the Rancho add-a-leaf suspension upgrade would allow me to fit 32X11.50's on my Jeep? Any feedback would be wonderfull, oh, and, does the Add-a-leaf kit come with all necessary U-bolts replacement parts??
Thanks,
95 2.5L bumpers and hilift, soon to be locked and lifted!!!!
95, 2.5L, custom bumpers, Flow's, 4 inch Skyjacker Super Duty, 33x12.50 MT's, 15X10 AR 767's, Hi-lift, Funk in the Trunk( two 12 inch subs ), soon to be locked and have one of those pully things on the front.
If you are going to be a bear, be a grizzly...
Mike611 is offline
post #2 of 6 Old 02-16-2002, 08:54 AM
TDanks76
1979 CJ7
My answer is, probably not. i was looking at the same thing a while ago and figured it wasn't worth it. The add a leaf will give you about one or two inches of lift. So why not just spend the extra bucks and buy a 2.5 kit like the Rancho or Rubicon Express. This way you get new spring packs, u bolts and quick disconnets, plus all the nessary parts. ( I don't think you get u bolts with the add leaf) Then to insure your not going to rub those 32 tires go with a one inch body lift.
I'm in fact doing that set up once the weather clears.
This is just my opinon I'm not an expert, but I hope this helps you out a little.
CJ 7, with the good stuff.
TDanks76 is offline
post #3 of 6 Old 02-16-2002, 11:31 AM
rodgersmc
Mike I've got a 3" body lift and a 2" shackle lift and I still rub the back wheels on fenders occasionally on trails, and I have 32" wheels... so I doubt you'd want a 2.5" lift with 32's unless you are street only.
89 YJ 4.2L
3" body lift
2" shackle lift
32" tires on 15X10's
winch
soon to be JKB2 mod
rodgersmc is offline
post #4 of 6 Old 02-16-2002, 07:37 PM
love24wheel
love24wheel's Avatar
32" wheels huh? Those are some BIG wheels.. Heck, I had 32" TIRES once.. I can't imagine what a 32" wheel would look like... LOL
89 yj with tires and stuff like that.....
Black Jeep Member #22
love24wheel is offline
post #5 of 6 Old 02-16-2002, 08:05 PM
95yj-4 cyl
I have a Superlift 3 1/2" lift, running 32" Superswamper tires on stock 7" rims, and have no rubs at all. I had a 2 1/2" lift on another YJ , with 32" BFG's on aftermarket 8" rims, and it rubbed hard until I put a 1" body lift too. Even after the bl, it still rubbed at full flex, but not as bad. The biggest difference is that the aftermarket rims stuck out too much, where-as the stock rims allows the tires to tuck almost perfectly inside the fenderwells. You can get a complete 3 1/2" to 4" for between $400-550 (depends on brand).
95 yj, 4 cyl, auto trans, 4:88 gears, detroit front locker, rear detroit with super 35 kit, short shaft conversion, 4" superlift, 32" superswamper radials
95yj-4 cyl is offline
post #6 of 6 Old 02-16-2002, 08:27 PM
rodgersmc
d'oh! I hate when I do that... makes you look stupid ;-)... anyway, you know what I meant. 32 tires on 15" american racing wheels with 10.5" rims.
technically... a wheel is a round object that moves something on it... so the tires are part of the wheel... but i'll stop trying to redeem myself.
89 YJ 4.2L
3" body lift
2" shackle lift
winch
soon to be JKB2 mod
Got my tires rotated. Now tires are excessively loud at highway speeds. televisionary Tires & Wheels 16 06-09-2010 08:45 AM
Help me with a logical solution for wheels/tires for my JK (want bigger tires) jcole JK Wrangler Technical Forum 8 01-27-2010 06:47 PM
TIRES PAST FENDER FLARES 15.5 in wide TIRES!!!! johnjr602 TJ Wrangler Technical Forum 57 10-14-2009 05:50 PM
What tires size tires are you running on a 3 inch lift afaletto YJ Wrangler Technical Forum 8 07-01-2009 01:04 PM
31" Tires and Stock Tires on New Wheels arcteryx23 TJ Wrangler Technical Forum 9 01-18-2006 09:26 PM
