Will switching from MTs to ATs gain back some gas mileage? - JeepForum.com
post #1 of 16 Old 11-10-2007, 03:25 PM Thread Starter
slater03
My gas mileage with my 33x12.50 kumho mts is about 12-13 mpg. The mts arent necessary for me since I barely go mudding anymore so I was thinking about swapping on some 32" or 33" ATs like BFGs or something. Would the ATs get me better gsa mileage?
"Witty quote here"
slater03 is offline
post #2 of 16 Old 11-10-2007, 03:36 PM
cumnzdzl
I would say no unless you go smaller. I dont think tread pattern affects it near as much as tire size and gearing. Just keep your 33's and regear. If yoou have a 6 cylinder buy a set of 4 cylinder axles with 4.10 and if you have a four cylinder buy a set of 4.56 or 4.88's probably the same money to buy new tires or regear.
97 Cherokee Country, all stock.... For now
SOLD 1993 Wrangler, 4 cylinder with a bored out TB spacer intake manifold and a 4.0 HO TB, 5 spd, herculined tub, 1in Performance Acessories BL, JKS 1in BMML, TJ Flares, Rubicon express 4in lift, M.O.R.E. 5/8" Boomerang Shackles, and 35x12.50x15in BFG Mud Terrains
cumnzdzl is offline
post #3 of 16 Old 11-10-2007, 03:48 PM Thread Starter
slater03
I really dont want to spend any money though and 4.10 axles would make it undriveable on the highway since with 3.55s now its about 3000rpms a 70
"Witty quote here"
slater03 is offline
post #4 of 16 Old 11-10-2007, 04:46 PM
Big-n-Broke-YJ
BUILT. NOT BOUGHT.
Big-n-Broke-YJ's Avatar
the mpg you MIGHT gain from the switch to at's will not be noticeable. tire wear, however, would be....
i would switch to an AT for THAT reason, but not for fuel economy....
'89 Wrangler, 4.0/AW4, 106" Wheelbase, SOA, custom XJ packs, 2" Body. Front High Pinion Dana 44 w/yukon super-joints, chromo inners and outers, and a Lincoln Locker. Rear Dana 60 w/Yukon 1.5" 35 Spline chomo shafts and detroit locker. 5.38 Yukon Gears. Hydro-Assist, 39.5x18" Boggers on 15x12 RockKrawler's w/ 2.75" of backspacing. Comp cut, tube fenders, custom bumpers and rock sliders, fuel cell, CB, Stewart Warner Gauges, SmittyBilt XRC8 Winch, 140 Amp CS-144 Alternator, Electric Fan, and a cooler of beer. 3897 lbs
Big-n-Broke-YJ is offline
post #5 of 16 Old 11-10-2007, 05:07 PM
Nelliebelle7
I have a set of both. If I'm going to street it a lot I put on the AT's. Besides tread wear, I've noticed a 3mpg improvement. Not to mention better ride, handling, and noise level. The old YJ is almost civilized with the AT's on the street. I have to qualify that my AT's are 31x10.5
Nelliebelle7 is offline
post #6 of 16 Old 11-11-2007, 05:55 AM
tank29
Yeah, It's A Jeep Thing!!
tank29's Avatar
...Tire wear and ride quality would be the reason for the change. Increase in MPG would be so small you would not notice.
Todd
2007 JK Unlimited "X"
TeraFlex 3" Kit with 4 Arm Flex Kit, TeraFlex HD F & R Adj. Track Bar, Rock Krawler Spring Levelers, Yukon 5.13 Gears, Black Rock Soft 8 Steel Wheels 16x8 (4.25" BS), Cooper Discoverer STT 315/75/16, XRC Rear Bumper w/Tire Swing, Rugged Ridge Front w/Stinger, AEV Snorkel, Cobra 75, KC 130W Slim Lights w/Windshield Mounts, Xenon Flat Fender Flares
tank29 is offline
post #7 of 16 Old 11-11-2007, 06:01 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Not true. You would actually like it belive it or not. If your doing 70 alot, you want to be around 2300-2500 once your in that range.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #8 of 16 Old 11-11-2007, 07:57 AM
pasinbuy
Have you corrected your speedometer for the 33s or is your speedo still off?
If it is still off the 12 to 13mpg number is wrong and your milage is about 10% more making it 14mpg to 14.5mpg.
Does that sound better?
pasinbuy is offline
post #9 of 16 Old 11-11-2007, 08:03 AM
jeeepguy
jeeepguy's Avatar
You've got the non-overdrive factory TF999 3-speed auto... they burn more gas than a stick. You have three choices really:
  • a) Replace the gears with 3.07s... that will lower your ratio and the RPMs all around, giving you less power but better mileage. Your freeway RPMs will be around 2200-2400 at freeway speeds
  • b) Lower your tire size to a 31" at most. That will accomplish the same thing as above
  • c) Get a tranny that has .75 overdrive like an AW4 from a Cherokee or a .7 overdrive 700R4. Both will give you a reduction in RPMs back to stock
The third option is the best but most expensive. The second is the least expensive but the one most people don't like due primarily to vanity". "Ewww... lower my junk, no way".
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #10 of 16 Old 11-11-2007, 11:25 AM
claytonandson
claytonandson's Avatar
maybe completely irrelevent,but what kind tire pressure are you running. i know my mpg seemed to go a couple of more miles when i went back 32 psi on a/t's(probably my imagination). i was running 26-28 #'s before.just rides a little rougher and i can always take some out when needed.
yellow jeep club #343
IAFF /FF's OF WASH. D.C. EMERALD SOCIETY/CHARLES COUNTY RESCUE SQUAD 51
claytonandson is offline
post #11 of 16 Old 11-11-2007, 11:30 AM
93jeepREDSOX
When i had bfg a/t's they were louder then the trxus m/t's I have now. I really don't think that you will notice any difference in mpg's unless you regear.
1993 YJ 4" RE lift, 1/2" shackles, AA SYE Kit, 33x12.50 Trxus M/T, Warn bumbers front and rear, Warn M8000 winch, 4 Hella fog lights, Magnaflow cat, flowmaster muffler with no tailpipe, herced tub, tj flares
HOW BOUT THEM REDSOX
The build thread
My Rigrator score 535RRv1.0 BOA 25
93jeepREDSOX is offline
post #12 of 16 Old 11-11-2007, 02:01 PM Thread Starter
slater03
I was really considering swappint in a aw4 or atleast a lockup 32rh but I dont think the mileage gained back would make up for the iunitial investment. My whole goal is to save as much money as possible and I was hoping to find someone with ATs willing to trade for my MTs. And the noise and ride improvements would be welcome.
"Witty quote here"
slater03 is offline
post #13 of 16 Old 11-11-2007, 02:26 PM
jeeepguy
jeeepguy's Avatar
My AW4 swap cost me $600 total with all parts and materials. I went from 13-14 in the city to 16 or so and 15 on the highway to 18. I was driving about 160 miles a day back then and paid back the tranny cost in about three months. Its well worth it, even with lesser driving.
Doug Patton
Revelation 13:16-18
Think about it...
jeeepguy is offline
post #14 of 16 Old 11-12-2007, 08:36 AM
coachchuck
I disagree.
The milage difference for me is measurable, at about 2 mpg.
However there are a lot of variables that can change this.
My AT and MT are both 33s,
but the ATs don't weigh as much as the MTs.
I run about 28 psi in the ATs, the MTs at about 22 psi.
Chuck
Sold : 93 YJ, 33s, 4.1, HO 4.0, AX15, d300 flipped
Building 90YJ. 37s, 5.38, 350, 4L60, np241, d44-ARB, D60-spool
coachchuck is offline
post #15 of 16 Old 11-12-2007, 11:45 AM Thread Starter
slater03
I was claculating it up one day and I figured $300 for the cheapest tranny Ive seen, SYE (which I dont have now) $400, and new front driveshaft and I figured it would be close to $1000. I drive maybe 240 miles a week (roughly a week for very fill up) so it would take me forever to pay it off. I think Ill just search for some 32" ATs even if it wont save me much mileage.
"Witty quote here"
slater03 is offline
Best/cost efficient way to gain HP and gas mileage zanash2 TJ Wrangler Technical Forum 117 03-11-2009 11:16 AM
switching back to regular oil xjgnar TJ Wrangler Technical Forum 10 10-14-2008 05:58 PM
Remove The Cat? Gain Anything? SOLOLUCKY YJ Wrangler Technical Forum 1 06-04-2008 08:49 AM
Switching back from synthetic motor oils JQlaxTJ TJ Wrangler Technical Forum 14 12-07-2005 07:12 AM
switching back to black fender flares? dirkpitt73 TJ Wrangler Technical Forum 4 01-06-2005 05:55 PM
