Will this skid plate fit on my 92 YJ? - JeepForum.com
post #1 of 3 Old 08-14-2011, 07:27 AM Thread Starter
zoltan
I want to replace the gas tank skid plate on my 1992 YJ. I'd really like to put a stainless one on so I don't need to worry about it rusting. I found one made by Kentrol, but it says it only fits 87-90 YJs. Does anyone know what the difference is between the 87-90 YJ and my 92? Would it fit my 92? Would it be easy to make it fit?
http://www.quadratec.com/products/12518_8000.htm
http://www.jeep4x4center.com/kentrol...ate-30539.html
zoltan is offline
post #2 of 3 Old 08-14-2011, 07:53 AM
jbolty
jbolty's Avatar
1990 and older 6cyl had a metal tank, most of them 15 gallons. Everything was poly after that with an internal fuel pump. The 4 cyl already had poly but maybe the size changed there too.
Stainless is softer than normal steel and will offer less protection. If you are worried about rust drill a few drain holes in a new skid and put a few coats of paint on it. The one you have now has lasted 20 years.
Personally I would use the opportunity to get something with serious armor.
jbolty is offline
post #3 of 3 Old 08-14-2011, 08:07 AM
YJDave
I went with the Warrior Products Gas Tank Skid Plate. Thicker steel and powder coated. I wouldn't trust that flimsy stainless version.
YJDave is offline
JP0020 Skid Row engine skid plate mmarmouz TJ Wrangler Technical Forum 3 11-13-2009 10:06 AM
Skid Row Evaporative Canister Skid Plate mrsig JK Wrangler Technical Forum 6 01-26-2009 07:46 AM
Anyone run a Muffler skid plate? A skid plate like the Kilby? JK Zombie Butt JK Wrangler Technical Forum 1 09-04-2007 02:51 PM
skid row radiator skid plate victory red TJ Wrangler Technical Forum 17 12-26-2006 11:46 AM
Engine Skid Plate, Or Oil Pan Skid? BNovak TJ Wrangler Technical Forum 2 08-04-2004 04:25 AM
