will it run if timing chain is off a tooth - JeepForum.com
post #1 of 8 Old 09-23-2010, 08:49 PM Thread Starter
tranzamwayno
we've been working on my friends 94 2.5L wrangler and it has been sputtering on occasion (while accelerating) and backfires (on acceleration) now and then, if your easy on the gas it runs pretty good
fuel filter has been changed and plugs, wires cap rotor, new.
the timing chain was really ticking loud, so we replaced it and the tensioner
still runs the same, maybe even worse
if the original chain jumped a tooth would it even be drivable
if we installed the chain off a tooth would it even be drivable
the dots lined up. with the cam sprocket dot at 1 oclock, there was a link at 3 oclock on the crank sprocket and 20 pins between the dots, just like the manual says
when timing mark is on zero the rotor points at 3 oclock towards front of engine, like the book says for 94 2.5L
if the timing is correct i'm thinking maybe clogged converter even though it looks good and has no noise when pounding on the bottom of it
it does have pretty low pressure out the tailpipe compared to my 4 banger
going to compression test it tomorrow to see what the valves are doing
pulled a code no cam sync signal before we started , but it ran
now shows a 27code which is injectors not signalling correctly
pretty sure they are on correctly, (we replaced exhaust manifold) i pull each one of and engine sputters a little, positive wires match what the book says
any ideas any body
thanks alot!!!
tranzamwayno is offline
post #2 of 8 Old 09-24-2010, 12:46 AM
greyarea
Yes it will run. how it runs depends on what it has done. check the vacuum if the cam is retarded it will be low.
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
post #3 of 8 Old 09-24-2010, 08:58 AM Thread Starter
tranzamwayno
i'll do that, it doesn't ping or anything like the cam is advanced
post #4 of 8 Old 09-24-2010, 07:14 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
any ideas any body
thanks alot!!!
Get this engine up to TDC mechanically. Then check the orientation of the rotor as opposed to the #1 rotor tower position. If you need herlp let me know.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #5 of 8 Old 09-24-2010, 10:59 PM Thread Starter
tranzamwayno
well, timing chain was off a tooth, so it does run if its off a tooth, revs up great now, drives great but still has a hesitation and a back fire now and then, am going to try a new distributer next after making sure its in correctly
post #6 of 8 Old 09-24-2010, 11:44 PM
greyarea
When you re timed the cam you through off the distributor timing
KI4UTU
greyarea is offline
post #7 of 8 Old 09-25-2010, 07:54 AM
TehWicked
Timing light will save you alot of hassle here...
Distributor is more than likely your problem right now...
TehWicked is offline
post #8 of 8 Old 10-24-2010, 07:47 PM Thread Starter
tranzamwayno
swapped distributors and runs great now
thanks for the help
Timing help! Replaced timing chain now I can't get the timing right. yjcrawlr YJ Wrangler Technical Forum 29 04-09-2010 08:36 AM
Is this a bad Timing chain?? berg4068 YJ Wrangler Technical Forum 2 11-17-2009 05:25 AM
timing chain JRocker TJ Wrangler Technical Forum 2 12-16-2007 04:48 PM
Can a 4.0 timing chain set be used on a 4.2? rollerized YJ Wrangler Technical Forum 5 05-15-2007 07:55 PM
Timing Chain! Josephrk24 YJ Wrangler Technical Forum 3 12-23-2006 07:26 AM
