Will rear diff gears from '98 XJ fit in '90 YJ rear end - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Will rear diff gears from '98 XJ fit in '90 YJ rear end
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 10-11-2011, 09:57 PM   #1
ConSuedo
I have a '98 XJ and just replaced the rear end assembly and pops wants to lower his gear ratio in his '90 YJ. I have the old rear end from my XJ and my 3.07 is the change in gear ratio he wants to come down to from the 4.90 he has. Will my gears fit in the rear differential of the '90 YJ he has??? Much thanks for the advice!
ConSuedo is offline   Reply With Quote
Unread 10-11-2011, 11:36 PM   #2
Joe Dillard
Electric Chair Operator
The '90 YJ has a D35C, and the '98 XJ has either a Chrysler 8.25 or a D35C. So depending on which axle it has, it may not workie since the 8.25 & D35 parts don't mix.
Joe Dillard is offline   Reply With Quote
Unread 10-12-2011, 02:59 AM   #3
ratmonkey
Living dead mod
ratmonkey's Avatar
The xj could have either the 35 or 8.25.
I wouldn't want to set up used gears that old though.
ratmonkey is offline   Reply With Quote
