Will not go over 2100rpm - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Will not go over 2100rpm
SPARTAN LOCKERS are on sale BIG TIME at ROCKRIDGE 4WD!Bds fox ipf 2.0 racing series shocks now available at rockTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 01-12-2015, 02:27 PM   #1
HMFIC
HMFIC's Avatar
1994 I6 TF999 3 speed auto
Will not go over 2100rpm in 1st gear. No problem hitting the higher rpm on the highway when down gearing from 3rd to 2nd. But if I get it going in 2nd and down gear to 1st it goes right back to 2000-2100 rpm and won't budge over that. I want to says it might be the torc converter but it doesn't do it when going from 3rd to 2nd. Any insight would be greatly appreciated!
Has new headers, cat, muffler and has good flow out of tailpipe.
HMFIC is offline   Reply With Quote Quick reply to this message
Unread 01-13-2015, 06:47 PM   #2
HMFIC
HMFIC's Avatar
Bump
Unread 01-13-2015, 10:30 PM   #3
Luuca
Typical /F12 Hooligan
Luuca's Avatar
Let me understand this.
When you downshift, it bogs down and drops the tach to 2100 rpm? Thus slowing the vehicle? As intended?
Does it rev over 2100 in 1st from a dead stop? Or does it shift at 2100 into 2nd?
Is the Trans COntrol Unit on the TF999 a seperate unit than the ECU? If so, have you made sure it's good? Swapped it for another unit to see if it acts the same?
I only have experience on the AW4 in XJs and those have seperate TCU behind the glove box area. I had a trans that was shifting all funky. Took a look at the TCU module, and the PO must have put some cologne or perfume in the glove box that leaked onto the TCU and corroded the connector. Once cleaned up it shifted just fine.
91 YJ "Alice" 2.5L, AX5, 2.5" OME 36Rs, Revolvers, 32" Yoko ATs, 4.10 D30/35 Aussie Lockers F/R Busted Knuckles YJOTM Someday
05 LJ Rubicon "Ghost" 4" RE Lift, 1.25" BL, 35" Goodyear MTS, 4.10 D44 F/R Locked
Luck Favours The Prepared
Luuca is online now   Reply With Quote Quick reply to this message
Unread 01-14-2015, 10:23 AM   #4
HMFIC
HMFIC's Avatar
Will not go over 2100 rpm from dead stop. I am not sure if the TCU is separate or not. I was thinking it was it all was off the ECU. I will check into the TCU/ECU when I get home. Thank you!
Unread 01-14-2015, 10:40 AM   #5
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
After doing work in the area I think I would be looking closely at the linkage on the throttle. Maybe the kickdown lever or something is out of whack limiting the throttle.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is online now   Reply With Quote Quick reply to this message
Unread 01-14-2015, 11:13 AM   #6
Luuca
Luuca's Avatar
I guess the question is can he get the pedal to the floor and conversely, does the butterfly respond accordingly. Good point Mike.
Unread 01-15-2015, 06:42 PM   #7
HMFIC
HMFIC's Avatar
In park/neutral it revs normal. I rev'd it close to redline here. It revs the same with pedal.
Dead stop to me standing on the skinny pedal.
Unread 01-15-2015, 06:48 PM   #8
HMFIC
HMFIC's Avatar
Those are videos if you click on them. Not sure why it didn't show up that way.
The throttle linkage and cables look good.
Unread 01-17-2015, 01:16 PM   #9
HMFIC
HMFIC's Avatar
Help
Unread 01-17-2015, 03:33 PM   #10
Mike Romain
Originally Posted by HMFIC View Post
Help
Can't see your videos, does the throttle physically open all the way?
Mike
Unread 01-18-2015, 11:06 AM   #11
HMFIC
HMFIC's Avatar
broken video
Unread 01-18-2015, 11:09 AM   #12
HMFIC
HMFIC's Avatar
still not wor5king it seems
Unread 01-18-2015, 11:11 AM   #13
HMFIC
HMFIC's Avatar
It opens up all the way in park/neutral and has no problem hitting high rpms at highway speeds
Unread 01-18-2015, 11:13 AM   #14
HMFIC
HMFIC's Avatar
broken video again
Unread 01-18-2015, 05:05 PM   #15
HMFIC
HMFIC's Avatar
YouTube (Short URL)
?start=" frameborder="0" allowfullscreen>
