will a new motor help my love life? - JeepForum.com
post #1 of 9 Old 10-24-2012, 09:36 AM Thread Starter
riverhippy
i bought an ax15 to put behind my 2.5. the 2.5 has been rebuilt except for camshaft and bearings. the kit to fit the ax15 costs $442 the inline 4liter with 150,000 miles costs $300.
it has a lifter tick in no 6. are there any propeller blades im walking into? im not too worried about the swap but don't know much about the motors longevity or reliability. any input will be appreciated.
riverhippy is offline
post #2 of 9 Old 10-24-2012, 09:54 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's a jeep. You're always trading one problem for another predicament. Personally, I would rather have potential than a dead end street especially if you're already subconsciously going to do it anyway. I mean, c'mon. You know you wanted the 4.0 from the beginning!
Also you should factor in the sale of the 2.5 into the equation because those numbers are all that matter when the job is done. At least to the bikini clad vixen in your profile.
Luck Favours The Prepared
Anticanman is offline
post #3 of 9 Old 10-24-2012, 02:48 PM Thread Starter
riverhippy
ill have to tell my girl shes a "vixen"...haha. the vixen really does dress the jeep up nicely.
post #4 of 9 Old 10-24-2012, 07:50 PM
pete1991YJ
On any engine that I ever bought, I always insist on seeing or hearing it run first, in person if I can. Otherwise itsa just a pile of parts to me. Unless I know the seller personally real good.
That said, it could be easier way to go for your AX15 swap. The motor swap does require a lot of attention to details (wiring) and weld new engine mounts.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #5 of 9 Old 10-24-2012, 09:25 PM Thread Starter
riverhippy
welding new engine mounts?
post #6 of 9 Old 10-24-2012, 11:04 PM
pete1991YJ
The 6-cyl has them in a different spot on the frame - farther forward. Which means cutting them off the frame and re-welding them in the right spot for the new motor.
post #7 of 9 Old 10-25-2012, 10:54 PM
rambo3489
I say go big or go home when it comes to my Jeep. I personally would get the 4.0L and see what happens. Actually I would get both. and mate the ax-15 to the 4.0L. It's 300 bucks you would loose out on with the 4.0 if it goes south. It will probably be good enough to last you though. I've seen some crazy sounding Jeeps that keep on chugging. Literally. Plus you can sell you 2.5 for lets say 200. A 4.0L for $100. Sounds good to me.
A lot of work ahead tho, especially if things go wrong. But I would do as stated. Just to get more out of the old girl when things get dirty.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #8 of 9 Old 10-25-2012, 10:59 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Female fox. Just a friendly compliment.
post #9 of 9 Old 10-26-2012, 09:21 PM Thread Starter
riverhippy
ok....im jumpin off...gonna start a new thread for the motoswap
boobs , bouncy , girls , motor replacement , rod knock
