Will i damage my t-case? - JeepForum.com
post #1 of 10 Old 11-04-2011, 11:51 AM Thread Starter
Danny915
I have an 88 YJ with a set of tires that are pretty bald. I have a set of Dunlop Rover A/T 235/75/15 for the back that are about 50% thread and a set of Scorpion Radial A/T 205/75/15 with about 80% thread for the front. If I run a set of tires in the front with different thread and slightly narrower than the back can i damage the t-case or front diff?
-Danny
Friend-"Hey why are you so rough with it?" Me-"Dude listen, it's a Jeep, is what it was built for"
1988 Jeep Wrangler 5spd,4.2L,Weber Carb, Holley Regulator,Electric Fuel Pump, Goodyear Duratracs 31x10.5x15, ZONE 2" lift kit, RC stabalizer,
Danny915 is offline
post #2 of 10 Old 11-04-2011, 12:26 PM
NicksYJ
No you should be fine, the only time you run a risk is when you run 2 different size tires on 1 axle than you run a very high risk of grenading your diff.
NicksYJ is offline
post #3 of 10 Old 11-04-2011, 12:36 PM
jbolty
jbolty's Avatar
If you have tires front and rear that are different diameter they will obviously rotate at different speeds. But, unless they are wildly different and / or you engage 4WD on dry pavement it should be ok for a while.
Having different sizes on the same axle would make no difference; the whole purpose of a differential is to allow left and right tires to turn at differing speeds.
This is a good education
jbolty is offline
post #4 of 10 Old 11-04-2011, 01:27 PM
raynmaker
Call me old fashion but "Never run different size tires on a 4X4" was what I was taught. just my 2 cents. Look on craigslist for some that match.
Warning: This poster has infinite knowledge of useless information and redneck tendencies. Use info at your own discretion. :wave:
raynmaker is offline
post #5 of 10 Old 11-04-2011, 02:41 PM
Chris
Guy with jeep
Chris's Avatar
Those two tire sizes mentioned are just a width difference as far as I know which will not make a difference to your Tcase. You would have more of a problem if say you wanted 33's up front and 35's in the rear.
Chris is offline
post #6 of 10 Old 11-04-2011, 02:44 PM
iced98lx
Few things:
  • Would not affect anything in 2wd anyway
  • When you're in 4wd there should be some give/slip (not dry pavement surface) anyway so that helps
  • THey're the same height, so it should be fine
iced98lx is offline
post #7 of 10 Old 11-04-2011, 09:53 PM
jeepnbrett
Those tires are not the same diameter. The 235/75-15 converts to 28.9 inches and the 205/75-15 is 27.1 inches. You will be fine in 2WD but do not run it in 4WD in any place where there is much traction. You will put a lot of stress on your transfer case.
Brett
4.0, AT, 3.5 Fabtech, 1" SRS, 1" BL, 35x13.50x15 Toyo MT's, HP30, TJ shafts, Lockrite, 8.8, Power Trax No Slip, 4.11's, Warn bumpers, W8274, SYE, and a bunch of other stuff....
jeepnbrett is offline
post #8 of 10 Old 11-04-2011, 10:55 PM Thread Starter
Danny915
Alright I will try and get a used set of tired before the snow hits thank you very much for the advice
Danny915 is offline
post #9 of 10 Old 11-04-2011, 11:25 PM
ROTTEN
Great video!
ROTTEN is offline
post #10 of 10 Old 11-04-2011, 11:57 PM
tankinyj
tire diameter is what would determine this. if they are say 31" on every tire, than you will be fine. i used to run 2 different tire patterns on my XJ when i didnt have the money, same size.. never had a problem
2012 JK, 44s locked on 4.56s, 4:1, 3" on clayton arms, 37" PBRs
Crush Orange Jeep Member #55
tankinyj is offline
