will cable driven slip yoke work with electronic speedometer? - JeepForum.com
post #1 of 5 Old 10-19-2009, 10:04 PM Thread Starter
nnojeeps
I found an '87 YJ at the junk yard with a SYE. I want to place it on a '92 YJ that I have. Will this work or will the cable speedometer be a problem? I have an electrical speedometer.
nnojeeps is offline
post #2 of 5 Old 10-19-2009, 10:08 PM
Gobi_Gred
1987 YJ Wrangler
The SYE should'nt affect the speedo at all. Did you do a 4.0 swap? I'm not sure I have ever heard of a digital speedo in an 87. Is it aftermarket?
Gobi_Gred is offline
post #3 of 5 Old 10-19-2009, 10:13 PM Thread Starter
nnojeeps
The '87 YJ is a cable driven speedometer. My '92 YJ has an electric pickup for the speedometer. Will the electrical work with this application?
nnojeeps is offline
post #4 of 5 Old 10-19-2009, 10:35 PM
Gobi_Gred
1987 YJ Wrangler
Duh! helps when I actually READ what you wrote.The SYE should not affect your Speedo pickup. I am assuming they are both 242s If it your pickup bolts up the new TC it should work.
post #5 of 5 Old 10-19-2009, 10:49 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
I think you mean 231s, the 242 is a part time/full time case used in XJs, ZJs & WJs.
OP, look closely at the '87 T-case. Most '87s came with NP 207 cases.
Here is some info from the FAQs:
Transfer Cases
The transfer cases used are all chain driven with aluminum housings. NP stands for "New Process" which is the brand, if you will.
NP207 - "Command-Trac" part-time only - 2.61:1 ratio low range - only in 87
NP231 - "Command-Trac" part-time only - 2.72:1 ratio low range - shift pattern 2H - 4H - N - 4L - used '88-'95
Link to FAQ
http://www.jeepforum.com/forum/f12/y...-specs-563403/
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
Electronic gauges to wire driven? ryanfivetwo YJ Wrangler Technical Forum 6 03-30-2009 03:45 PM
Exploded my slip yoke housing and pinion yoke. durangoyj YJ Wrangler Technical Forum 53 01-12-2009 02:58 AM
Swapping out mechanical speedometer for electronic one. Oorin YJ Wrangler Technical Forum 3 01-31-2008 08:13 AM
Electronic Speedometer on a 91 YJ Mr. Tobes YJ Wrangler Technical Forum 3 10-28-2006 10:22 PM
Electronic Speedometer COJAM YJ Wrangler Technical Forum 19 03-22-2005 03:15 PM
