Will a bad VSS prevent starting?
#16 | |
I just grabbed an ECU out of a '92 XJ w/4.0 and 5 speed.
Still no start. Now it is possible for this ECU to be bad as well, but it was worth a try. The ground from the battery to the block is good. The coil only has the harness plug and wire to the rotor. Is there a ground wire for it? Anybody have any ideas?
US Army combat vet Armed Forces Jeeps Member #125 Red Jeep Club Member #251 In the Portland/Vancouver area? Check 'em out! Piston's Wild Motorsports Club Click here for 2.5L AX5 to AX15 swap |
#17 |
Are you still getting the fault? Start with the basics. You are dealing with fuel, air, spark, and timing. Pull injector and see its putting fuel in. Pull a plug and look for spark, throw a timing light on it and see what the timing is looking like. Are you sure the vacuum lines and connectors for the sensors on the manifold by the breather are hooked back up after your mod?
#18 |
Did you ever find out what the problem was??
It only hurts while you're breathing.. |
#19 |
I know this is an old thread but if you are sure you are getting spark, I would still test the coil because it might be weak.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride 1991 YJ Sahara 4.0L Automatic 1978 Dodge Lil Red Express - work in progress |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
